It is currently Sat Aug 19, 2017 10:38 am
Post new topic  Reply to topic  [ 13 posts ]
PostPosted: Wed May 01, 2013 1:41 am
There have been a few times this year during races where I've had to work at VO2 max (or at least what I think it is - 95% of max HR or 5% above LT) for several minutes (closing breaks or trying to hang on some of the more aggressive climbing efforts), but have found that after I dip into that zone, even getting my HR back up to LT is extremely difficult.
What do you guys recommend to train to recover from these types of efforts mid race? Ideally, I'd like to be able to do at least one more effort at that level. Or, am I asking too much?
Strava
Current Stable. The Snob Machine | The Crumpton
The Ex's. LS Siena: 6.21kg | Parlee Z5 SLi: 5.9kg | LS Xicon: 5.76kg | C59: 5.7kg | Cervelo R5ca: 5.09kg | Fuji Altamira SE - 6.2kg | Scott Foil - 6.2kg | Evo - 5.18kg | LS Classic - 6.7kg
PostPosted: Wed May 01, 2013 1:58 am
Intervals. Lots of them.
My Bikes
My Photoblog
PostPosted: Wed May 01, 2013 2:00 am
It's hard to make recommendations based on such little information.
How long are said climbs? Is the pace still relatively high/moderate on top of the climb?
Depending on duration you could be using a fair bit of anaerobic contribution to your efforts which is hard to recover from when the pace is kept fast.
You could be dipping to high above your FTP and then riding arround your FTP to recover which would make it feel quite hard. There would be a few good workouts for that. What duration are you looking for?
PostPosted: Wed May 01, 2013 2:09 am
Second on what fa63 said; as for which intervals perhaps try some over unders? I'm a really big fan of 30s/30s at 90%/110% FTP for as long as possible or for a set interval around 20mins. You can tweak the numbers and durations but the basic idea is pretty straight forward.
650b Ritchey
Colnago Mapei
S-Works Tarmac
PostPosted: Wed May 01, 2013 6:06 pm
Well, pre-race, of course, more interval training.
During the race, when you feel yourself approaching "the edge" concentrate on deep breathing and relaxing while turning the pedals smoothly.
Easier said than done. At some point you really are just outclassed and you go back to interval training.
PostPosted: Wed May 01, 2013 7:57 pm
Climbing as a whole usually isn't a problem as I'm generally sitting at LTHR on most climbs around here, unless someone attacks and I'm trying to maintain with the attacking group.
An example of the problem area was last race, where I was responsible for bringing back a breakaway near the end of the race. Most of the lap I was in Zone 2/3 (Friel's HR zones seem a little wonky, but my HR was between 155 and 163 -- I have a LTHR of 180). For 4:18, I averaged 27.3 mph on the flat with a headwind with my HR topping off at 189 bpm, for an avg HR of 185 during the effort.
Once I brought back the breakaway, I sat in the pack to recover back at Zone 2, but only got 2:30s before we went into the final climb. At that point, I tried to hang on, but couldn't ramp up my effort past LTHR and got dropped.
I had a similar situation happen at a circuit race (bridged to a breakaway group, rested and got my HR under control but then was spent). I had more time to recover at the circuit race, but once the effort ramped up again, I couldn't get past LTHR even for a short while to make it over a small powerclimb.
Granted, 189bpm may just be my point of no-recovery, but I'm still curious if there's a combination of intervals or what have you that can make digging that deep for 3-4 minutes not so detrimental to the rest of the race.
Strava
PostPosted: Thu May 02, 2013 1:28 am
either ditch the HR strap or tape the HR display on your computer during races. You seem to be driven by your numbers a lot. I dont race with my HR (actually never use the HR strap) and I go on feel during races. If I can hammer, I hammer. If I can follow, I follow. If I can't, my body will tell me and it will be obvious.
Reading your post you seem more concerned about you HR not droping back then the actual sensations during the race.
PostPosted: Thu May 02, 2013 1:53 am
+1
I was absolutely terrified by my heartrate in a couple races, so I stopped wearing it.
No correlation at all to training. ....unless "always +40 BPM above prior maximum" counts as a correlation.
PostPosted: Fri May 03, 2013 1:35 am
OK, let me rephrase the question since providing my heart rate information seems to be derailing the conversation (I do keep my HR info on a second, out of site screen during races).
Rephrased Question:
What is the best workout to prepare for being able to, in a race, perform a 4 min effort at near max perceived effort, recover for 4 min or longer at moderate/low effort and then reproduce the same 4 min near max effort?
Now, the reason I provided HR info was because I would tell you that my second 4 min effort was at a perceived near max, but if I had a power meter, it would only be at FTP or less.
Is the answer for me to incorporate 4x4 intervals?
Strava
PostPosted: Fri May 03, 2013 1:56 am
I would work a range of intensity, increasing your ftp would be good for that purpose. Higher ftp would mean less redlining for a given power output.
I'd also work in vo2max type of efforts, 4-6x4min, 4-5x5min, 4-6x3min. You can also work these shorter efforts with different pacing strategy such as starting hard and finishing hard, or starting hard and survive untill the end.
Over under efforts would be good too. Some 5min to 20min efforts alternating between sub threshold intensity and supra threshold intensity.
PostPosted: Fri May 03, 2013 7:41 pm
Stop doing stupid shit like bringing back breakaways. If your team is the only team not represented and its threatening, then sure, but even a lot of cat 2/3 breaks can't organize enough to get away. Even then, share work with your teammate or emphasize its just your role. I get stuck in this position sometimes, do my pull, then recover. I always see riders taking massive pulls for really long periods of time, blowing up, etc. or just wasting energy.
Sounds to me like you wasted a bunch of energy and didn't have the gas when the real move went. Sounds like a deficiency of tactics as well as power.
I used to do a lot of vo2 max work as I found it gave me that extra oomph in races and really allowed me to top off my FTP and 3-5min power thus helping in a lot of road race situations. This year I did exactly 5 vo2 max workouts the entire year:
6x3min with 3 min rest. Ride 10min, then 4x2 (Did that one twice)
4x8min with burst every 2 min. Rest 4 min (Did that one once)
40/20 for 6-8 reps for 2-3 sets (Did these twice)
A very experienced local NRC pro/coach (I'm talking years on the road with teams like Navigators, multiple championships) told me last year he has riders do no more than 5 weeks of vo2 work before peaking that the fatigue is not worth the risk of doing the work longer nor does it produce any bigger results.
So far this year after doing this work I've felt a lot stronger and a lot more fresh in races. I've been in situations in hard 1/2/3 crits where I had to pull back a break or be active in a doomed early move and have had more than enough punch to do so and very good recovery between efforts. Don't overcomplicate it.
Gramz
Failed Custom Bike
PostPosted: Sat May 04, 2013 12:04 pm
It must depend on what else your are doing and time available, but I pretty much did vo2 work all winter long this year, this means december, january, febuary and march and im still doing one workout a week. I have never been in that kind of form. I did very little sustained work and piled up some long rides when I could ride outside.
Depending on what you are doing, I think you should hit the intense stuff.
I like that 8min workout, might give it a try, would you hit them at arround 105% FTP?
PostPosted: Sat May 04, 2013 2:08 pm
Easiest way to have race recovery after a vo2 level effort is to train for it.
Find a 2km long 6-9% hill, and do vo2max intervals up it. When you get to the top, turn around, head back down, roll off the hill, turn around, and head back up.
I have a nice 2k long hill here with a 7.5% gradient. It's perfect :)
At minimum, you want to do 2 hc's. But preferably 3 or more if your fit enough.
There are no new unread posts for this topic. Concussion recovery
in Training
glepore
9
902
Thu Feb 09, 2017 4:42 pm
Kermithimself View the latest post
There are no new unread posts for this topic. Would doing a recovery ride on the same day help you recover faster for the next day?
in Training
Shrike
9
1051
Tue May 23, 2017 8:06 pm
AJS914 View the latest post
There are no new unread posts for this topic. Comfortable office chair to aid recovery?
in Training
sib
20
1341
Mon Mar 27, 2017 11:51 pm
saeie1 View the latest post
There are no new unread posts for this topic. How do you structure your "rest/recovery" week?
in Training
jeffy
Tue Mar 21, 2017 8:40 am
boysa View the latest post
There are no new unread posts for this topic. Race Clincher Tyre
[ Go to page: 1 2 3 4 ]
JamesGRC
50
4510
Tue Aug 08, 2017 5:22 pm
apricotwalnut View the latest post
Users browsing this forum: Sjoerd and 1 guest
