It is currently Wed Jan 17, 2018 12:27 pm
Post new topic  Reply to topic  [ 11 posts ]
 Post subject: Shoes Bont or Bontrager
PostPosted: Thu Mar 14, 2013 2:28 am
I am currently using the Bontrager RXXXL limited edition shoes. I am looking to purchase a pair of 2012 Bont Vaypor shoes. Should I stick with my Bontrager shoes, or would the Bont Vaypor shoe be an upgrade worth purchasing? Would I notice any performance advantages? Thanks
PostPosted: Fri Mar 15, 2013 1:06 pm
I currently have the Bont A-1's.
I was curious about the Bontragers so I stopped at a BS and put them in my feet to "feel" them.
I'd say these shoes are at the opposite in terms of fit and comfort.
The Bontragers being the comfortable ones.
Bont's are special shoes. Don't buy them expecting a "usual" fit. Prefferably put them on, try them first.
Louis :)
PostPosted: Fri Mar 15, 2013 7:10 pm
I can't speak to the Bontragers but I had Bont A-ones. Very poor finish for an expensive shoe, odd fit (have to go at least 2 sizes up and for me too wide when finally long enough). On the good side Uber stiff and low stack height. I thought of them as a great crit or tt shoe but not good for me for long days. Ended up replacing with S Works which were fantastically comfortable till the sole broke.
I would not buy them unless you have tried them on (okay true for any shoe). Obviously you can tune the fit somewhat as far as hot spots and such but for me they just weren't great. Also they are not a shoe you can really ride some days and put on your more comfortable shoe for longer days because the stack height is so low you really do need to adjust saddle position.
PostPosted: Mon Mar 18, 2013 3:12 pm
IME the only reason Bonts aren't comfortable is you get tired of re-molding em and just give up. Took me 4-ish tries to get mine right. There's one niggling little spot that I've been meaning to address, but its a 'roundtoit.'
AFA shoes: completely different critters. Stack heights are going to be off, etc.
M
PostPosted: Mon Mar 18, 2013 9:59 pm
Interesting, Wiggins in this picture is wearing Specialized shoes! http://4.bp.blogspot.com/-5PELNlRpFwg/U ... iggins.jpg
PostPosted: Thu Mar 21, 2013 10:21 pm
I don't know about your bontrager rxxxxxxxxl shoes but when I switched from Scattante (Performance brand) shoes to Bont CTT-1s (basically A-1s) it was a world of difference. It takes some patience to heat mold them to fit your feet well but when you do they are great. Super stiff shoes and they grab your foot extremely well without feeling like they're choking your feet. I can ride them without ratcheting them down no problem. Added plus, they are fairly light too.
Regarding the size, if you measure your foot out as explained on their website and pick the correct corresponding size you shouldn't have a problem. From what I've seen online people complain about the sizes being off when they used the same size as their old shoes, and that's just silly.
PostPosted: Sun Mar 24, 2013 12:42 pm
I don't gave any experience with the Bontrager, but have owned Bont A1's for 3 years.
They are very stiff, as already mentioned and it took some trial and error before the fit was perfect.
They became a pleasure to ride because of the immediate power transfer. It feels as though the effort is rewarded very quickly.
The negatives, which they have started to address are the longevity of the uppers. Mine delaminated/ unglued rather quickly.
The shoes also have begun to wear through the heels at a much more advanced rate than any other shoe that I owned (many)
Despite the negatives, they are light, and the low stack height draw me to try another pair.
Cheers.
PostPosted: Mon Apr 08, 2013 4:21 am
It all depends on your foot. Shoes and saddle discussions are a dime a dozen b/c they affect everyone...........differently. Like the saying goes, if the shoe fits.........
I recently bought some Bont Vaypors (2012) and they are much different than the Lake, Sidi, and Diadora shoes I own/owned. Super stiff carbon sole, wider toebox, super lightweight. Mine have the Speedplay drilling instead of the standard 3-hole Look drilling and that alone made a noticeable difference to me anyway. I'd say look at your bare foot, heck even trace an outline of your feet on a sheet of paper like what Bont recommends and compare it to other shoe toe boxes and heel cups. I can tell you from experience, a properly fitting pair of shoes is WELL WORTH the cost no matter what the brand so make sure whatever shoe you pick fits your feet like a glove. I read good things about Specialized shoes also, but you aren't the first to have broken one of those soles either. I bought my Bonts b/c I like that style and the toe box and heel cups fit soooo well AND they are a infinitely moldable shoe. Being lightweight was an added bonus. I still could probably try remolding mine 1 more time to achieve fit nirvana, but right now they aren't bad at all and the quality looks to be really good as well. Good luck in your decision.
PostPosted: Fri Apr 12, 2013 12:31 pm
Hey mate,
I use the 2012 Vaypors and am now on my third pair.
1st pair the carbon broke up on the sole ... my own fault
2nd pair hit by a car and the Ambulance Officers cut them off
The other posts suggest the molding problems, which I too experienced with my first two sets ... I took my time and where I had a lump on toe or whatever I wrapped tape around it first put a slightly thicker sock on and molded each shoe at a time... then twice to ensure that I hadn't missed anything that may dig in or rub .... I also run ESOLES and they are the most comfortable shoe I have ever worn. I have had nothing but good dealings with Steve N.
Saving madly now for a pair of the new Boa models 8)
NB:
I had Bontrager RXL , Specialized Road Pro , Nike Carbon previously
2012 KUOTA KOM Team Edition Campag SR11 .....My mistress
2012 RIDLEY HELIUM being built up ....
PostPosted: Fri Apr 12, 2013 2:54 pm
I know a Bont rep who used to be a sponsored pro speed skater who recently told me to save my money if I wanted something that lasts so that says it all.
I also know a kid that used to be on the Bontrager Livestrong team and one that is now. They all universally hate the shoes and many of them train in something else.
I wouldn't buy either.
Gramz
Failed Custom Bike
PostPosted: Fri Apr 12, 2013 2:58 pm
I have a pair of the 2013 RXXXL SE's, and coming from a set of the 2011 RXL's, they're much better. Haven't tried the Bont's yet, as I got an incredible price on these, but in terms of fit and finish, the Bonty's are great shoes.
There are no new unread posts for this topic. New shoes, Bont and Giro?
PLuKE
19
1545
Tue Aug 01, 2017 4:10 am
nemeseri View the latest post
There are no new unread posts for this topic. FS: Bont Vapor + Road Shoes White Size 45 $100
boots2000
Tue Oct 31, 2017 11:05 pm
boots2000 View the latest post
There are no new unread posts for this topic. bontrager xxx lite tubulars and bontrager cork pads - squeal
in Everything wheels
campagowlo
Wed May 31, 2017 7:04 pm
meltedbakebeans View the latest post
There are no new unread posts for this topic. Oddball request: Indoor cycling shoes? Spin class shoes?
in Training
kkibbler
7
1085
Sat Mar 11, 2017 2:38 am
Nefarious86 View the latest post
There are no new unread posts for this topic. Bont Vaypor+ and Look Keo issues
girona
Mon Jun 19, 2017 7:24 pm
TwiggyTN View the latest post
Users browsing this forum: No registered users and 1 guest
cron
