Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Fri Feb 08, 2013 4:24 am
I am a school teacher, but I am on a limited time schedule with Saturdays off for coaching. Saturday will be considered my rest day. What type of workouts are there to accomplish in a 30-45 minute time period that I can benefit from? I want to focus on all areas of riding: climbing, distance, and Sprinting. One each day if possible.
Thanks
There are many, many threads on this. Please use search
PostPosted: Fri Feb 08, 2013 9:48 am
So what your looking at is 3 hard days, 3 easy days, 1 rest day
Hard days are 20-25km, Should take 50-60mins. 8-10km warmup at a slowly increasing pace to hard, then either of the following
- 3 x 250metre sprints all out. Rest between sprints are 3km rolling recovery. Roll down is 5km
- Find a 5-8% gradient hill 1.5-2.5km long hill approx 7-9k from your house. Do 2 hillclimbs at vo2max level. i.e. your only just starting to blow up completely in the final few hundred metres (92% max of HR), recovery is roll down hill, roll off hill for a few hundred meters, turn around and repeat, going hard by start of climb. Rolldown is return to house. (the 2nd time up will hurt bigtime!)
If your sprinting, use the same circuit, with the same sprint points. Note your max speed, and also note any winds you encounter during each sprint.
If your hill climbing, use the same hill, time each from a start point to an end point.
You will see improvements over time if you keep a diary.
As far as distance is concerned. If you can do a 2 hour ride at tempo pacing 50% of the time, this will also result in good adaption. (85% of max HR for half your ride distance). i.e. warmup for 10-15k, then ride at a level that has you needing to open your mouth to breath. Do an initial 3-5k tester building up to 85% HR. Rest for 1km. Then do 10km effort at tempo pacing. then rest for a few k. Then do 20ish k at tempo pacing. And then recover, and add additional efforts depending on distance. Roll down is 5-10k.
All these hard days need a easy day either side. 20km on flatish ground at recovery pace is ideal.
If your really strapped for time and can't get a distance day in, replace it with a lactate threshold short distance day. i.e. 25k, 5-10k warmup, then tt for 10-15km at ftp (89% max HR). 5k warmdown.
Cheers,
metal
/\ p.s. I use to do this kind of training when I was racing u/17 and had school and thus minimal time to train during the week /\
Users browsing this forum: Exabot [Bot] and 3 guests
There are no new unread posts for this topic. Thoughts on 3 days on, 3 days off training schedule.
in Training
jgf37
12
693
Mon May 06, 2013 5:16 pm
jgf37 View the latest post
There are no new unread posts for this topic. Limited training time advise needed
in Training
bm0p700f
10
661
Thu Mar 07, 2013 6:54 pm
dvincere View the latest post
There are no new unread posts for this topic. Attachment(s) Mixed Drivetrain Replacement Schedule
frankq
Tue Jul 17, 2012 10:33 pm
bm0p700f View the latest post
This topic is locked, you cannot edit posts or make further replies. Training plan
in Training
razer1
Fri Jun 22, 2012 11:27 am
razer1 View the latest post
There are no new unread posts for this topic. Help with tweaking my training
in Training
welkman
20
1673
Sat Feb 23, 2013 2:20 pm
welkman View the latest post
It is currently Sun May 19, 2013 3:09 am
