Post new topic Reply to topic  [ 17 posts ]
Go to page 1, 2  Next
PostPosted: Fri Jan 04, 2013 4:04 pm
When I do my FTP testing during the summer I have a route that's not completely optimal. I guess the best thing would be a relatively flat course with no corners. Well, this is a course with rolling hills and some corners where I need to slow down quite a bit. So I was thinking whether or not it would be better to look at normalized power instead of average power for FTP?
I like Spanish bikes and cars. Riding an Orbea Orca and a Seat Ibiza.
PostPosted: Fri Jan 04, 2013 4:17 pm
if the time at zero cadence is minimal, I'd use the average power without zeros. Other method would be using the trainer for a consistant method with your (20min test ?) or do a ramp test on the trainer, its shorter and a consistant protocol will give you a good idea of your progression.
2013 rocky mountain vertex 29er
­Twitter
www.cyclingtrainingnuts.blogspot.ca
PostPosted: Fri Jan 04, 2013 5:28 pm
Depends on the duration of your test and what software you use. You can always smooth the file a bit, but I think a better thing is to see how much NP and AP vary. Its supposed to be a quasi semi state test so if its like 3-5w I wouldn't worry a ton, but if its a big amount I'd find a new way to test.
PostPosted: Fri Jan 04, 2013 6:57 pm
i tested outside from march til about august (missed 1 or two months), but like you it wasn't super ideal in a sense where somewhat rolling, and 2 acute roundabouts where i would have to coast through them....1-3 seconds. You can see the elevation change in the strava link i posted.
but from those 20minute test , and using the adjusted FTP for future workouts, it seemed to work well.
i just had to remember to put on my 11t to pedal (and keep power up) downhills, and go into small enough gears while going up hill to maintain the same cadence but somewhat steady power. someone will probably come in here and tell me my protocol sucks, but ehhhhh i am not bothered to change it for outside and will probably continue on 2013 the same when testing outdoor =)
segment highlighted below...
http://app.strava.com/activities/23458419#z2386|3594" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
PostPosted: Tue Jan 08, 2013 5:12 pm
In theory you should use normalised power, since it calculates the equivalent constant power output you would have achieved if you had ridden on a perfect course.
But in reality I wouldn't get too hung up on using average power. In my view it's a useful measure since if you can do 300W round the test circuit with a few gaps in pedalling, then you can also achieve 300W on a typical ride on a similar circuit.
PostPosted: Tue Jan 08, 2013 11:34 pm
Online
I would say use average power; FTP is a training metric first and you want it to reflect your ability over your typical training and racing terrain. Its nice to see the bigger number that np will likely provide but it will also likely make your workouts too difficult (assuming you are training on ap and on similar terrain as your test circuit).
"But when you hit that asphalt down below nothing else matters, your pulse is skyrocketing toward 200"
Speed Concept
Colnago Mapei
S-5 VWD
PostPosted: Wed Jan 09, 2013 10:51 am
Thanks for the replies. But what if we look at it differently? Let's just asume that I've done an FTP test, and the NP and AP are different.
AP: 300 watts
NP: 315 watts
Now, I'm setting off on a 40 km TT, but if I aim to hit my AP level, my AP at the finish line will probably be lower than 300 watts when accounting for turns, coasting, braking etc. Whereas if I aim to hit the NP level, I'll probably cross the line with an AP of 300 watts. Situation 2 will get me quicker across the line?
Would this be correct to assume?
PostPosted: Wed Jan 09, 2013 1:12 pm
just try one. see what happens...
PostPosted: Wed Jan 09, 2013 5:47 pm
Online
If you're seeing that big of a gap during a FTP test - you're pacing is bad. Most FTP test/ITT should have AP and NP within a few watts of eachother.
PostPosted: Wed Jan 16, 2013 8:54 pm
Like Ghost said.
There's no point in a 20 min test where you should not be pedalling.
Thus your AP & NP should be pretty much the same.
PostPosted: Sat Jan 19, 2013 9:15 am
Or as the OP said, the course is less than ideal.
I simply dont have a course that is really suitable either and my VI is often 1.05-1.08 on a FTP test.
But in the end it doesnt matter, so long as the test is repeatable and you are getting a similar VI in each test, I wouldnt worry about it at all and would use NP.
PostPosted: Wed May 29, 2013 7:55 pm
I have done 2 FTP tests and average power in these tests is identical. Today I did 25km TT and 20min avg is 12w higher. Should I take todays number as my FTP? -5% of course.
file: http://connect.garmin.com/activity/319874002" onclick="window.open(this.href);return false;
"Nothing compares to the simple pleasure of a bike ride"
Scale 30
Schenk 007
My blog
PostPosted: Fri May 31, 2013 2:49 pm
I'd certainly use the more recent 'test' (read: best 20 minute power) as the basis for your FTP.
Also try an ergo 20 minute test to see how that compares to the power you produced in the TT.
Looking at that file, it also looks like you might have been one gear too high as well. Cadence is good, but maybe just a little high to allow you to be really 'over' the gear.
PostPosted: Tue Jun 04, 2013 12:43 pm
Looking at your ride, you did 305W for 20min, but 302W for the whole 40min TT. I would guess that your FTP would be a bit over the 290W that would be 95% of 305.
As I just said on another thread, I wouldn't try and ride to such a precise value unless you have Tim Kerrison on your coaching team. Keep an eye on your 30s power for dropping below about 280. or up above 350ish.
If you just want to set a value for training zones, I'd go for 295-300. If you find that you consistently fail to hit the numbers during your workouts, then HTFU. ;) No, drop it down a bit, or make sure you aren't doing too much.
Snacking on carrot sticks - Where did it all go so wrong?
Finsbury Park CC
PostPosted: Tue Jun 04, 2013 2:03 pm
Yes, I want to set a value for training zones. If I take 95% of 302, it would be 287.
In two FTP tests, I have done, FTP was 278. I did those tests in april and may.
After this TT I changed FTP value in my computer to 287w.
Scale 30
Schenk 007
My blog
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 4 guests
There are no new unread posts for this topic. Power and cyclocross
in Training
dwilson
Thu Jul 19, 2012 7:35 am
markrhino View the latest post
There are no new unread posts for this topic. power question
in Training
williamsf1
Mon Dec 17, 2012 9:09 pm
There are no new unread posts for this topic. The old man and the sea of training with power
in Training
hasbeen
10
1319
Wed Oct 31, 2012 4:57 pm
Krull View the latest post
There are no new unread posts for this topic. Has anyone here tried to modify an EPS power unit?
Artisan
12
1240
Wed Oct 10, 2012 4:31 pm
Omiar View the latest post
There are no new unread posts for this topic. Rotor Power details
CharlesM
15
1255
Thu Sep 06, 2012 9:51 pm
CharlesM View the latest post
It is currently Wed Jun 19, 2013 1:41 am
