Post new topic Reply to topic  [ 10 posts ]
PostPosted: Mon Sep 24, 2012 1:28 pm
Just curious how everyone here plans their race strategy
obviously course notes and elevation come into play, as well as relative strengths, weaknesses, whos good and whos not....
how early/ late do you plan race startegyu? the night before? the week before? make it up on the fly?
PostPosted: Mon Sep 24, 2012 2:33 pm
usually what happens is that i plan some elaborate plan after recon'ing the course and then it never plays out.
if u recognize strong dudes, try to stay with strong dudes if u can.
other than that, just try to cross the finish line before all the other guys
PostPosted: Mon Sep 24, 2012 2:58 pm
1) Are you riding with a team or solo; and
2) What kind of events are you contesting?
I do most of my planning 3-1 days prior to the event . You'll want an easy day or two to recover from training, so that's the most important part of your initial planning- that, and scouting the course. There's no point in over-planning since the race itself is so fluid. Look at Gilbert; a year ago, everyone knew his tactic would be to sit-in and just attack on the Cauberg, and that's a pro-level plan. Eat right, know the course, stay near the front, try to be first.
If solo, I would say recon the course, check weather the night before, try to figure out where the obvious challenges are on the course, and have all of your gear/papers/bike packed, prepped, and tuned the night before, and be well-versed in the particular course rules and stewards' plans. Day-prior nutrition should be common-sense; starches, limited fiber, avoid heavy grease, favor foods with polyunsaturated fats.
In terms of strategy, it should go without saying that you should follow a tapered program in the days before your event. There's no point in taking the start sore or exhausted when you can easily avoid it.
If you have a team, focus on the basics; what are your team mates' strengths, who has the best fitness at the moment, are you going to protect a rider or just try to stay together.
Road race or crit? The road race would require more recon and planning/strategy. In the crit, stay on the front, period. The crit also rewards day-prior recon of the course. If you're going to dodge the same manhole covers and frost heaves 20-60 times, you should be very familiar with their locations. Also, since crits favor momentum, try to find the best (safe) lines through the turns. Since any car can dump it's entire oil pan on a city road at any time, getting a look at the road surface the day prior and morning of your crit is big.
-Tim
PostPosted: Mon Sep 24, 2012 3:02 pm
As far Road Races, Team strategics tend to work but individual strategics need to be played out as the race develops. Being a good rider has more to do with knowing how to play the game than being a strongest player.
2 Serotta's, 1 Spectrum, 1 Van Dessel, 1 Parlee & 1 Carl Strong, & 1 Titus.
PostPosted: Mon Sep 24, 2012 6:08 pm
- ride at the front
- know who are the stronger riders
- get in the winning move
simple :noidea:
team tactics
- chase down any breaks that a team member isn't in
- slow down the other riders in the main or chasing group :lol:
- take turns attacking the break and sitting in if two or more of you are in a break near enough to the finish for a solo move to work
PostPosted: Mon Sep 24, 2012 11:34 pm
Drop everyone off the wheel from the start and go solo all the way.
I've done that.
PostPosted: Mon Sep 24, 2012 11:41 pm
You also have a w/kg that is approaching Pro levels :lol:
No need to boast :roll:
PostPosted: Tue Sep 25, 2012 5:38 am
1) Check out the course - identify significant landmark areas (big hills, open fields, etc.)
2) Check where the wind is coming from
3) Know how the race played out in previous years
4) Know your strengths/weakness (and teammates)
From there I basically make up a strategy based on what I know. I'm more of a diesel type rider, so if there is a short steep hill, I know that I want to be at the front to minimize my movement backwards into the peloton. If I know there is wind coming from the right side, I want to hide on the left. Along with that is team strategy, knowing the other riders, etc.
PostPosted: Tue Sep 25, 2012 4:28 pm
Another thing that I haven't seen anyone mention is to target areas that are technical or seemingly easy but can be made hard. When races go through curvy or technical sections I make sure I'm on the front pushing the pace, because you create a very difficult accordion for the pack. I also like to try and push the pace over the little rises and other sections that look easy but allow you to push the pace up slightly and force people further back in the pack to speed up to keep up. Other good examples of this would be cobbled sections or dirt sections, you can make big gaps over short sections, burn a match and cost them ten. If you can review the course before, it makes selecting the right areas much easier than just doing it on the fly in the race. This works fantastic if you have a team helping as well; a whole, well conditioned team that frequently rides together, working on the front through a technical section can really rip apart a race. This happens constantly in pro races, they know right where they need to be pushing all the time.
Other than that do what everyone else is saying; stay at the front, cover moves, pedal the least and then the hardest.
"But when you hit that asphalt down below nothing else matters, your pulse is skyrocketing toward 200"
650b Ritchey
Colnago Mapei
S-5 VWD
PostPosted: Wed Oct 24, 2012 11:23 pm
I like to just go with the flow.
With 20 minutes to go, I like to maneuver to the front so that with 15-10 minutes to go, I can launch an attack. It generally fails, at which point I like to seek out the strongest riders, get on their wheel, and prepare for the sprint.
Unless of course, my teammate's on a flyer. In which case, it's block, distract, and block.
Those are crits.
I only train on days that end with "y".
Eli
Users browsing this forum: Google Adsense [Bot] and 4 guests
There are no new unread posts for this topic. 24 hour team-race. Strategy?
in Training
Fyssen
Thu Aug 30, 2012 7:13 am
Fyssen View the latest post
There are no new unread posts for this topic. XC race bikes
in MTB
clouchi
Mon Sep 03, 2012 11:44 am
thisisnotaspoon View the latest post
There are no new unread posts for this topic. Allez Race or EVO 56.5cm
in Wanted
dmoneysworks
Fri Apr 12, 2013 10:28 pm
dmoneysworks View the latest post
There are no new unread posts for this topic. First race next weekend.....
welkman
28
1027
Sun Mar 10, 2013 7:01 pm
micky View the latest post
There are no new unread posts for this topic. Attachment(s) the new race bike!!
thebatman
7
1236
Tue Oct 09, 2012 4:01 pm
Stolichnaya View the latest post
It is currently Thu Jun 20, 2013 6:53 am
