Post new topic Reply to topic  [ 3 posts ]
 Post subject: MTB on Turbo Trainer
PostPosted: Mon Sep 17, 2012 7:47 pm
Hi there Guys,
I have a few question regarding running a turbo trainer with a mountain bike.
Do I need a special type of turbo trainer or will any one do or the adjustment (up/down) will be enough??
I understand that i need to change tyre from a knobbly one to a slick but do you have any suggestions for what slick to get or should I use turbo trainer special tire (if any exists)
Any thing else that i need to do/ get to be able to run it.
All help appreciated
Thanks
Tom
IRONMAN 70,3 TARGET TIME 03:55
 Post subject: Re: MTB on Turbo Trainer
PostPosted: Mon Sep 17, 2012 8:00 pm
As far as I am aware any turbo trainer should be fine.
I use a Continental Tyre dedicated for turbo trainer use. They are the only company producing such a thing as far as I know. It is a large volume tyre so the diameter isn't too different to the diameter of a road tyre on a 700cc wheel and hence adjustment is no problem. I also find quieter and hard wearing. Most (all?) turbo trainers should also be able to run a very thin 1 inch road style tyre in a 26 inch size (hence smaller wheel diameter) with an adapter bracket which should be included with the turbo.
PostPosted: Tue Sep 18, 2012 9:32 am
My old Tackx uses a screw to reposition the resistance unit. It came with some extra plastic bits to move the resistance unit up to meet a 26" tyre. So check before you buy. I guess it would depend a bit on the tyre as well, as diameter would vary a bit between an the extremes of an 18mm time trial tyre and a shaved 2.5" mtb tyre.
Users browsing this forum: No registered users and 2 guests
There are no new unread posts for this topic. Garmin/SRM on Turbo Trainer Question
airwise
Thu Nov 08, 2012 7:55 pm
ms6073 View the latest post
There are no new unread posts for this topic. Turbo trainer vs outdoor riding
[ Go to page: 1 ... 5, 6, 7 ]
konky
92
2201
Thu Mar 28, 2013 3:22 pm
jedijeck View the latest post
There are no new unread posts for this topic. Turbo trainer 'rig' or fixed steering frame for stability?
Ruds
Thu Jun 21, 2012 11:14 pm
Ruds View the latest post
There are no new unread posts for this topic. Elite Qubo Hydromag Elastogel turbo trainer: unstable?
Roark
Thu Nov 29, 2012 2:48 pm
Pharmstrong View the latest post
There are no new unread posts for this topic. cycleops indoor trainer or Proform Tour de France trainer
in Training
nismosr
Thu Nov 15, 2012 12:55 pm
drhule23 View the latest post
It is currently Wed May 22, 2013 7:59 pm
