Post new topic Reply to topic  [ 21 posts ]
Go to page Previous  1, 2
PostPosted: Tue Aug 07, 2012 12:06 pm
I am still not convinced. Put a 20lb backpack on and climb a hill in the same gear you would without the backpack and get back with me.
I realize that's extreme but you will get the point.
I still say the best way is for op to just test ride both options and decide for himself. Shouldn't be that difficult.
TIME RXR
PostPosted: Tue Aug 07, 2012 2:29 pm
Adding weight resistance has nothing to do with which combo of gears you use to propel the same weight over the same distance under the same conditions. Doesn't matter what gear combo produces the ideal gear inches, the ideal gear inches stay the same.
PostPosted: Wed Aug 08, 2012 5:22 am
agreed w Kwalker, gear inches is gear inches.
...a couple extremely minor points, though. gear efficiency generally starts going down when the gear has less than 16teeth. that, and there can be (slight) drag when cross chaining in the small ring due to chain sideplate friction against the big ring. but as i said, splitting
hairs.
on how many gears you need to dump when using a 36/52, i mentioned it's 4 or 5 gears. with those rings, i have a 12/25 11sp cassette. going from the 36/15 (eighth cog) to a 52/21 (third cog) increases my gearing ever so slightly (2.4 vs 2.476..). so for me it's five-ish gears.
PostPosted: Mon Aug 20, 2012 9:07 am
I personally wouldn't agonise too much about it. Easiest thing to do is to borrow a bike from a friend and ride it for a couple of weeks to see if that gearing works.
Two tips:
Ensure your gears are low enough to get home after you blow on a long ride at the end of a hard training week.
Second tip is that you do not have a personal mechanic, so forget about switching gears for flat rides and hilly rides.
I would recommend 52x39 and 12-25 as a good starting point if you're strong and there are no steep 500m vertical ascent climbs where you live. Then once you've worn those out you can try something else.
PostPosted: Wed Aug 22, 2012 1:35 pm
I have been training racing and riding on a compact for the last 3 years. The only time I wished I had a standard crankset was at over 80Kmh and 140 odd cadence down a hill...... On a recreational group ride......
Never once ran out of gears in a sprint.
No brainer for me.
Don't let the truth get in the way of a good story......
Argon
CAAD9 6.78Kg
Supersix 6.78Kg
PostPosted: Wed Aug 22, 2012 2:09 pm
I got a set of praxis 52/36s earlier this week after riding compacts for the last year..
Loving the extra topend. But I do like fast descents and not having to push 140rpm in a 60kph + sprint is a bonus too :thumbup:
http://fairwheelbikes.com/cycling-blog/ ... ee-z5.html
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
Users browsing this forum: No registered users and 2 guests
There are no new unread posts for this topic. Possible swap anyone? Standard Clavicula for compact.
CarpetFibre
Thu Feb 21, 2013 8:00 pm
CarpetFibre View the latest post
There are no new unread posts for this topic. WTT: SRM Hollowgram standard spider for compact spider
in Wanted
laleme
Sat Apr 20, 2013 3:04 pm
laleme View the latest post
There are no new unread posts for this topic. Handlebar compact
physeter
Sat Sep 01, 2012 4:25 pm
em3 View the latest post
There are no new unread posts for this topic. compact to semicompact
civdic
9
1031
Fri Sep 14, 2012 3:42 pm
tmanley View the latest post
There are no new unread posts for this topic. Clavicula 172,5 /130 trade to compact 172,5 or 175
in Wanted
Simon BP
Mon May 13, 2013 9:27 pm
Simon BP View the latest post
It is currently Sun May 19, 2013 3:47 am
