Post new topic Reply to topic  [ 11 posts ]
PostPosted: Tue Jul 31, 2012 8:37 pm
So I've had a Garmin computer for years now and every incarnation I've had - 305, 705, 800 - have all had the same problem with wind screwing up my HR reading. If it's not winter and I'm not wearing 3 or 4 layers, every single time the wind kicks up or I'm descending, my HR "spikes" to 230 or so. As long as there is very little wind, the reading is perfectly fine. Any ideas on how to mitigate this problem aside from wearing several layers to block the wind? Or am I the only one with this problem?
PostPosted: Tue Jul 31, 2012 10:14 pm
http://www.dcrainmaker.com/2010/08/solu ... pikes.html
PostPosted: Wed Aug 01, 2012 1:03 am
I was having similar spiking problems with my (non-garmin) heart rate monitor as well. I tightened the strap to be very snug and began wetting down my chest and the electrodes and it hasn't happened since. If you're already wetting down the contact points, apparently there are gels that you can purchase for the same purpose. Maybe the gel will resist drying out like water in the wind and work better.
PostPosted: Wed Aug 01, 2012 5:14 pm
probably said already, but i think it has to do with drying up of the salt/sweat contact between the strap and your chest. i notice that if i have my jersey unzipped and descend for 1-2 minutes, my HR (sometimes) will read 240bpm haha. zip the jersey back up and HR lowers to normal.
PostPosted: Wed Aug 01, 2012 7:50 pm
I think the consensus is right: it's the dry air here in Denver that's the culprit. In a stiff headwind and on descents, it dries me out and my moisture is gone. Even with the jersey fully zipped, it makes no difference. I think I'll try pulling the strap to the side like that one blog post talked about. Hopefully that works. At worst I'll settle with using some KY jelly on my HR strap. Or whatever the hell it is. haha
PostPosted: Thu Aug 02, 2012 6:37 pm
Static electricity build up from flapping clothing can also cause the HRM to spike. I get the same thing with lose fitting jerseys, and especially wind jackets that flap around in the wind. I tried riding in the winter with a nylon wind jacket over a wool jersey and never had the HRM show anything lower than 250 bpm.
PostPosted: Fri Aug 03, 2012 2:07 pm
bc sparks wrote:
Static electricity build up from flapping clothing can also cause the HRM to spike. I get the same thing with lose fitting jerseys.
The same happened to me, and by now I can point out my Jerseys where I know it will happen when I wear them for training.
Pfeiffer's Rennrad Camp and Cycling Coach
Independent HED Wheels/Powertap Dealer
PostPosted: Fri Aug 03, 2012 2:42 pm
The same thing happens for me in cool weather or on long descents. I open my jersey, lick my thumb and wipe it on the sensor pads to regain conductivity and everything is fine again. Don't forget to clean the sensor/strap off after training :scared:
monkeyburger
http://ocdlikeme.blogspot.com/
PostPosted: Fri Aug 03, 2012 5:40 pm
I had the same problem. Often, a splash of water deals with the issue just fine. Anybody know if bodyglide or a dab of chamois cream would work?
Cervélo S2 2012 Red
Great minds think alike... sadly, so do the mediocre ones.
PostPosted: Fri Aug 10, 2012 7:14 am
I used to have the same issue. When I switched to tighter "pro fit" (for lack of a better term) jerseys, the problem disappeared. Apparently, as others have noted, it was related to wind buffeting. I live in Arizona, so it is extremely dry here, as well.
PostPosted: Fri Aug 10, 2012 1:56 pm
You may also try wearing it (the transmitter portion) on your back, instead of the front.
It worked for me when I had the same issues with wind.
It is also improtant to, not just wet the soft straps, but to allow H2O to sit on the strap-sensor part until it soaks into it. (if that makes sense)
(you can see when water it on the sensor areas that is stands, but wait a bit longer and it diffuses into the soft materal. This is my experience with POLAR, at least)
Users browsing this forum: jdott and 4 guests
There are no new unread posts for this topic. SRM torque readings
in Training
CycleAlot
Fri Dec 07, 2012 9:08 am
malformedfawn View the latest post
There are no new unread posts for this topic. Powertap Readings on Kurt Kinetic Road Trainer
in Training
MAPhillips
10
486
Fri Apr 05, 2013 9:15 pm
billysan View the latest post
There are no new unread posts for this topic. "Low" power readings (badly mounted power2max cranks?)
in Training
tri
10
953
Sun Sep 09, 2012 9:05 pm
mrfish View the latest post
There are no new unread posts for this topic. Sram Limit Screws
Garret C
Thu Jun 21, 2012 6:24 pm
Camilo View the latest post
There are no new unread posts for this topic. deafened by the wind what to do?
roca rule
13
1039
Mon Dec 03, 2012 10:44 pm
stella-azzurra View the latest post
It is currently Sun May 19, 2013 6:02 pm
