Post new topic Reply to topic  [ 7 posts ]
PostPosted: Thu Jul 19, 2012 6:51 pm
Have been injured for over two months now with severly twisted right knee tendons, muscles and ligament.
Back on the bike for the first time yesterday, this is how I felt.
Bike: 2012 Boardman HT Pro MTB - 21.949lbs / 9.956kg (for now...)
PostPosted: Thu Jul 19, 2012 8:40 pm
Hey, good luck,
I'm on the same boat,
surgery for ACL "rupture",
lucky us, riding a bike is the first physical activity indicated for knee injuries :thumbup:
need to be careful not to catch a tendinitis because muscles around the knee that guide the patella have been weaken.
PostPosted: Mon Jul 23, 2012 7:52 am
Funny how cycling is often regarded as a sport easy on the knees. Do they mean leisurely rolling along? Hard riding can be taxing on the knees. Seems ample time to warm up is one of the important rules to abide by. I actually had good results with some massage oil applied before heading out.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
twitter: Falco_bike
Facebook: falco.bike
PostPosted: Mon Jul 23, 2012 10:30 am
This is definitely easy for the knees, even when riding hard and a lot.
Soccer, tennis, basket or running are a lot harder for the knees, a lot.
Tendinitis is the most common in cycling but this is nothing if you compare to cartilage, meniscus or ligament issues.
The only bad thing in cycling is the number of leg revolution. You have to start with a healthy knee because if you have a bit of "play" in the knee, cycling will definitely make it worse.
I did ride my bike as a rehabilitation before surgery of my ACL, and I had a bunch of play in the knee, and I caught a tendinitis in 3 rides.
PostPosted: Tue Jul 24, 2012 9:06 pm
It would depend on the gearing you use and the efforts.
Use lower gearing and higher cadence until the muscles get stronger around the knee.
I did have an ACL tear but I used cycling to rehabilitate it. I did not get an operation to repair.
It's been 15 years now since I tore it skiing.
PostPosted: Thu Jul 26, 2012 9:15 pm
Cycling is not only harmful to the knees due to repetition as Sammy Sanchez suggests and it is misleading to suggest cycling is not hard on the knees "when cycling hard and a lot". It is actually very demanding on the knees when riding like I guess most of us do. People often forget that cycling requires very strong muscles contracting across the knee. Add in to that co-contractions (e.g. the quads and hamstrings contracting and being active at the same time as each other when delivering power) and you can very quickly get very high contact forces and contact stresses in the various tissues of the knee.
Just because cycling isn't weight bearing in the same way as running does not mean forces acting in the knee are not high. It is just a different mechanism of producing high joint contact forces.
Cycling for rehabilitation is not intended to be anything like most of us would enjoy or be happy with. Cycling for rehab is mainly designed to get range of motion back (with very very light cycling) and to start to gently get the various muscles used to being active again. I would suggest really attacking more general knee rehab exercises suggested by your physio before trying to do too much on the bike. Get the knee feeling strong and settled again in all other walks of life (such as going up and down stairs) and don't be fooled into thinking cycling is easy on the knee :thumbup:
PostPosted: Sat Jul 28, 2012 3:36 am
I had surgery in both knees now. The last one, 4 months ago, acl.
Cycling is good to recover movement, strenght should be recovered with proper exercice, not with cycling. Using the seatpost a bit higher has worked for me in the first rides, less pain in the knee when pedaling.
Try to recover properly before running the bike as a treatment, it's not, it's a part of it, not it. Use the stationary machines in the gym, small weights, increase slowly, focus on the movement.
And btw, %#&k the knees.
Users browsing this forum: No registered users and 3 guests
There are no new unread posts for this topic. Carbon Fiber Kick Stand. 40g, $40USD
prendrefeu
21
1558
Thu Nov 29, 2012 11:21 pm
mellowJohnny View the latest post
This topic is locked, you cannot edit posts or make further replies. The REAL season has started!
liam7020
Sun Feb 24, 2013 1:49 pm
Powerful Pete View the latest post
There are no new unread posts for this topic. caad10 build started
pistol13
Sun Sep 02, 2012 12:07 pm
pistol13 View the latest post
There are no new unread posts for this topic. Dislocated knee.
in Training
Maximilian
10
339
Wed Mar 20, 2013 1:30 am
motorthings View the latest post
There are no new unread posts for this topic. TT Bike Knee discomfort
KingWeenie
Mon Feb 11, 2013 5:23 am
KingWeenie View the latest post
It is currently Wed May 22, 2013 3:06 pm
