Post new topic Reply to topic  [ 20 posts ]
Go to page 1, 2  Next
PostPosted: Wed Mar 21, 2012 10:33 am
Can anyone recommend a relatively cheap rear wheel that an ultegra 10 speed cassette will fit onto for use on a turbo?
I was going to use an old shimano wheel I had but the 10 speed cassette doesn't fit.
Is it recommended to use a wheel of the same type you normally run on the road as I'm running Mavic kysrium sl also with ultegra.
Don't want to be spending too much on a new wheel but don't want cheap equipment that isn't going to last.
Thanks
PostPosted: Wed Mar 21, 2012 2:46 pm
http://www.neuvationcycling.com" onclick="window.open(this.href);return false; has some ridiculously inexpensive wheels that are actually very good for training. Certainly they are good enough (or even too good) for a trainer. I have two pairs and they are solid as a rock.
This one ?
http://www.neuvationcycling.com/product ... k-1240.htm
PostPosted: Wed Mar 21, 2012 2:57 pm
Thanks for the reply. Thats something like what im looking for but as I hadnt put my location up its a bit impractical. And that site doesnt deliver to the uk.
Anywhere that delivers to the uk I could try?
PostPosted: Wed Mar 21, 2012 3:32 pm
Well, my favorite UK site is ProBikeKit, but I don't know if they have any wheels on sale.
It always boggles my mind how PBK can charge lower prices and get things to Utah USA faster than my LBS can get things from a manufacturer who is in town. :unbelievable:
PostPosted: Wed Mar 21, 2012 4:14 pm
how about 20 odd quid for a turbo tyre??
Cheaper than a wheel. (and probably better quality than a "cheap" rear wheel)...
Official cafe stop tester
PostPosted: Wed Mar 21, 2012 4:19 pm
Why not get something like Shimano WH-R500? That should do for training, and it never hurts to have a backup set of wheels.
(I've been trying hard to break my R500s but in over 5 years they have held up amazingly well.)
Bikes: Raceur, Beateur
PostPosted: Wed Mar 21, 2012 9:55 pm
I have a turbo tyre but would prefer having a dedicated wheel to save changing a tyre everytime I either decided to go on the road or the turbo.
Thats the set I was trying to fit my cassette to but my 10 speed cassette doesnt fit the hub, but after having had a look around I think ill go for a set of newer R501's so I can fit the cassette and they are only £90 a set.
Thanks
PostPosted: Thu Mar 22, 2012 1:26 am
Fulcrum 7s can be found for very little money sometimes.
PostPosted: Thu Mar 22, 2012 6:09 pm
+1 on the Fulcrum 7's. They are the standard wheels that come with Cervelo bikes and they tend to sell for very cheap because it's the first thing that Cervelo owners switch out. On the Cervelos however, they are labeled as Fulcrum Racing T - They are the same exact wheel.
Cervélo S2 2012 Red
Great minds think alike... sadly, so do the mediocre ones.
PostPosted: Thu Mar 22, 2012 7:03 pm
Thanks
The R500's should work......must be something else wrong here. R500's will fit a 10 speed shimano cassette. Take it to your LBS and they will fit the cassette for you if you can't get it on there.
PostPosted: Thu Mar 22, 2012 8:23 pm
Ive just checked the wheels again and the hubs are marked as WH-R550 and the rear ring seems to be all the way back on the hub.
PostPosted: Fri Mar 23, 2012 4:11 am
Those are 100% 10 speed compatible......I would take them to your LBS and get them to install the cassette....maybe there is a spacer behind the cassette you are missing or something.
What is the exact issue you are having that you are saying it doesn't fit??
PostPosted: Fri Mar 23, 2012 12:58 pm
In Canada, we have to spend a stupid amount of time on the trainer. There is really no need to purchase a specific wheel for the trainer, but if you must, you can buy a cheap POS, OEM wheel on Kijiji, etc., locally. Generally, the vendor will be sone Tri-geek tossing the OEM wheels on his/her new superbike.
PostPosted: Sun Mar 25, 2012 8:17 pm
Is it really recommended to have a separate wheel set for a trainer? I was under the impression trainers do not cause much wear.... Looking to buy a trainer soon, though, so this would probably be a good thing to know. :wink:
2012 Trek 1.1
PostPosted: Sun Mar 25, 2012 9:06 pm
I just thought it would be easier and save time changing the rear wheel rather than a tyre every time I was going to use the trainer.
I've read about wearing out normal tyres on a trainer but never experienced this with the michelin pro 3's I was using at the time. I've since switched tyres and don't want to wear them out.
Back to my earlier problem about the cassette not fitting, all is now fine. Thanks for all the help.
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 3 guests
There are no new unread posts for this topic. MTB on Turbo Trainer
in Training
tomgag
Tue Sep 18, 2012 9:32 am
mrfish View the latest post
There are no new unread posts for this topic. Garmin/SRM on Turbo Trainer Question
airwise
Thu Nov 08, 2012 7:55 pm
ms6073 View the latest post
There are no new unread posts for this topic. Turbo trainer vs outdoor riding
[ Go to page: 1 ... 5, 6, 7 ]
konky
92
2212
Thu Mar 28, 2013 3:22 pm
jedijeck View the latest post
There are no new unread posts for this topic. Turbo Trainer With Power Meter
in Training
viney
Fri May 24, 2013 10:45 am
DrGalactus View the latest post
There are no new unread posts for this topic. Elite Qubo Hydromag Elastogel turbo trainer: unstable?
Roark
Thu Nov 29, 2012 2:48 pm
Pharmstrong View the latest post
It is currently Sat May 25, 2013 3:13 pm
