Post new topic Reply to topic  [ 21 posts ]
Go to page 1, 2  Next
PostPosted: Mon Mar 05, 2012 9:34 pm
I was just curious what the difference in power output you are generally up against with each ascending racing categories (I know it can be variable, but I would just be curious to hear average wattages and how you competitive that put you). I would personally like to know because I'm a Cat 5 right now with an FTP of 3.6w/kg, and I'm not sure whether I would be strong enough to move up to a 4. I welcome any other inputs about other categories to, because hopefully I will be moving up to those spots in the future too.
How accurate would you say this chart is?
http://www.cyclingpowermodels.com/PowerData.aspx
PostPosted: Mon Mar 05, 2012 9:42 pm
it doesn't take a high watt/kg to cat up from 5 to 4. just race ur races =)
PostPosted: Mon Mar 05, 2012 9:47 pm
I just don't want to cat up, then feel out of my league (since you can't cat down).
PostPosted: Mon Mar 05, 2012 10:20 pm
if you can ride safely and stay in the pack in a cat5 race, you will be fine in cat4.
are you less likely to win a cat 4 race? yes. will you learn more in a cat 4 race? yes.
in cat 4 there will most likely still be a fair number slower than you, but also many more who are faster than you.
there are cat3 riders with FTP numbers not much better than yours...the difference is smarts.
PostPosted: Tue Mar 06, 2012 12:25 am
Yes. Plenty of Cat 3 riders with numbers at about the level listed but who have a great ability to draft, limit their losses on climbs, and position themselves at the end of a race. An exceptional sprinter has the capacity to close short gaps on MUCH MUCH stronger riders and hang on at least on the flats and shortish climbs. As long as they stay out of the wind - they can be fresh enough to do well at the very end. In my experience, the strongest rider with the best FTP numbers does not necessarily win - it is often the person who is freshest and who only has to make one REALLY good effort at the end to finish things off or place well.
Billy
PostPosted: Tue Mar 06, 2012 1:50 pm
The Allen Coggan Chart's seems accurate to me, I'm between Cat 3 and 2 with an FTP of 4.2w/kg: http://americanroadcycling.org/articles ... egoryTable
PostPosted: Tue Mar 06, 2012 2:29 pm
Which category do you race in?
PostPosted: Tue Mar 06, 2012 3:57 pm
FTP is very important but I find in racing is not the most important power numbers. Your 1-3 minute efforts are the ones that blow everyone off the back. I know some guys who's ftp is not so high but their two minute efforts blow everyone up. FTP keeps you in the race and anaerobic capacity wins the race.
2 Serotta's, 1 Spectrum, 1 Van Dessel, 1 Parlee & 1 Carl Strong, & 1 Titus.
PostPosted: Tue Mar 06, 2012 4:03 pm
I'm a 3rd Cat and placed top ten in a 2/3/4s race last weekend. Very poor sprint but good 5 minute power.
As a caveat I'm in the UK where we start at Cat 4.
PostPosted: Tue Mar 06, 2012 5:59 pm
That makes sense, especially if you're doing even 1-2 minute pulls. I guess what is even more important is you're anaerobic recovery. I have a pretty high 5 min power ouput compared to my ftp (1w/kg higher), but I notice when I try to replicate that power a second time in race it goes down dramatically.
Anyway, thanks Gem for the feedback. That was exactly the kind of information I was looking for.
PostPosted: Wed Mar 07, 2012 9:50 pm
Here is the way I break it down.
When I started, I raced as a Cat 5 like everyone else. Won ever race except for one and moved up to 4. The racing was a bit faster, but not much. Raced the rest of the season except the last two races. I had moved up at the end and wanted a couple races in my legs as a 3 before the winter. Next season as a 3, races were faster, but so was I and I raced until they kicked me out (Automatic upgrade). From there I raced as a Cat2 for two seasons and then moved my license to Cat 1. That was more just for my own personal goal, since where I am you race Cat 1-2 races as the majority.
If you look at who you are racing against now, the faster guys should be moving up together which means you will be racing the same guys a lot and you all get faster. Once you get to the Cat 3 level, I would stay there until you know each weekend that when you line up, you are going to be top 5 unless you have a bad problem. The wins come fewer and farther between in the higher levels.
HUMP
Why are the best things in life always the ones you start last?
PostPosted: Thu Mar 08, 2012 1:34 am
Thanks for the advice.
One other thing, does anyone have an idea of what kind of wattage a competitive cyclist puts out in a cat 4/5 for the final 30s? I usually average 750-800 watts max for my final sprint, and I always get beat so I'm assuming this is kind of low. I also just start to sprint when I see the other guys sprinting, is there an ideal time slot (like 20s before the finish line?) when you should apply maximum power (your anaerobic capacity)?
PostPosted: Thu Mar 08, 2012 2:27 am
My advice: Don't think about it and just race. If you get into the mentality that you "need" to be able to push a certain number just to compete - you've already lost the race.
750-800w for 30s is really impressive. I'm a cat 3 and my peak 30s is only 660w (I weigh 66kg) yet I was able to win many races as a 4. That kind of number should net you wins fairly easily if you live in a flat part of the world. I think the issue is your positioning leading into the sprint. My experience is that there will likely be one of two situations: (1) Everybody stays together and it becomes a field sprint or (2) Someone tries a flier and they either go alone or a select group is able to follow. If (2) happens, try to get into 2nd or 3rd wheel and just wait until you see an opening. This usually will happen 200-300m from the finish line, and you need to jump as hard as you can and push to the line.
I would suggest trying a flier next race and seeing how that goes. Try to find a spot that can allow you to jump hard and get away, a turn leading into the finishing straight is a great spot for this.
PostPosted: Thu Mar 08, 2012 2:43 am
Wow, amazing advice, thank you! I guess I probably shouldn't have put "average," that tends to be my max during the 30s.
I will give the "flier" method a try next time. I guess my problem has been that I open myself up to early (exposer myself to the wind) when the sprinting starts. I've never really understood how these lead riders decide to sprint, do they just just arbitraily pick a point from the finish line?
PostPosted: Tue Mar 13, 2012 4:33 pm
A 800w 30s is impressive indeed if that's what you were pulling.
And would be blowing a lot of guys away.
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
Users browsing this forum: alorast and 5 guests
It is currently Wed Jun 19, 2013 1:20 pm
