Post new topic Reply to topic  [ 5 posts ]
PostPosted: Wed Jan 18, 2012 11:46 pm
Hi,
I am trying to figure out how I can increase Q-factor (pedal width) on my cross bike.
The width of my hollowgram MTB crank with MTB BB spindle is perfect- wondering if I could run the same setup only with a compact road spider (for 36/52) on the cross bike?
My cross bike is a Specialized Crux with bb30.
I am pretty sure it will work- more concerned if chainline would be funky or anything like that.
PostPosted: Thu Jan 19, 2012 4:05 am
i havent worked out the math or anything, but here's one solution for the F'd up chainline:
get extra-long chainring bolts and nuts, and some bolt spacers the same width as the chainring tabs of the spider. mount the outer ring in the INNER ring position, followed by the spacers, and then the inner ring, and chainring nut. off the top of my head, it'll be close to ok.
PostPosted: Thu Jan 19, 2012 4:51 am
Your idea does not sound so good.
I may try to get my hands on the bb spindle to try it
PostPosted: Thu Jan 19, 2012 7:37 am
I forget how long the mtn spindle is...134mm? Road spindle is 104mm...so, seems like basically you'd just have to divide the difference and add that amount of spacers to each side of the shell. Though, I don't think I'd actually do it like that, simply because of chainline.
PostPosted: Thu Jan 19, 2012 8:02 am
Road spindle is 104mm. MTB spindle has been made in 122mm 128mm, 131mm, 132mm. 132mm is the current length. Using a mtb spindle your chainline will move out half the difference between the mtb and road spindle. 122mm-9mm, 128mm-12mm, 131mm-13.5mm, 132mm-14mm. So it'll pretty much suck!
If you want to get a q-factor like the mtb hollowgram on a frame designed for the road hollowgram get longer pedal axles or pedal axle extenders. I'm guessing you've got current model spindles on each bikes so you're looking to widen your q-factor by 28mm. Longer axles are readily available for Crank Bros and Speedplay. There are various companies offering pedal axle extenders as part of their 'fit kits'.
Grover's Grumblings
Grover's Garage
Users browsing this forum: Bing [Bot], Exabot [Bot] and 2 guests
There are no new unread posts for this topic. WTB-Cannondale Hollowgram Spider 110mm BCD Road
in Wanted
carlislegeorge
Thu Mar 14, 2013 12:01 am
carlislegeorge View the latest post
There are no new unread posts for this topic. WTT: SRM Hollowgram standard spider for compact spider
in Wanted
laleme
Sat Apr 20, 2013 3:04 pm
laleme View the latest post
There are no new unread posts for this topic. Hollowgram SI SL 130BCD Spider
in Wanted
doomith
Fri Apr 26, 2013 11:02 am
doomith View the latest post
There are no new unread posts for this topic. XX1 Spider for Hollowgram Released
in MTB
skiandbikecmh
Fri Mar 01, 2013 3:50 pm
dwaharvey View the latest post
There are no new unread posts for this topic. Attachment(s) Sram XX1 Spider for Cannondale Hollowgram
dwaharvey
Tue Apr 16, 2013 7:43 pm
It is currently Wed May 22, 2013 6:03 am
