Post new topic Reply to topic  [ 10 posts ]
PostPosted: Wed Jan 18, 2012 11:13 pm
I just built up my new Stevens Team carbon cross bike and i am running it with a single ring up front, so i need a chain catcher. The problem is the seat tube tapers very large at the bottom...towards the BB. My DogFang catcher won't go low enough to work with the huge taper in the seat tube. Any ideas for a chain cathcer to work in this situation? I am aware that the k-Edge one might work, not really wanting to spend $60 plus dollars...looking for a cheaper solution....any suggestions?? Thanks!!
to go faster....just pedal harder!
PostPosted: Thu Jan 19, 2012 6:36 pm
You could go the double bash guard route but there are also much lower cost K-Edge clones on Ebay (Rotor, Token, MTI). Just try a search for 'chain catcher' and you will get a large number of results for under $20.
PostPosted: Thu Jan 19, 2012 7:57 pm
i did the ebay search....the problem is i need one that goes way low, all the ones like dogfang, third-eye watch, and the others don't go low enough to reach my chain properly. The K-edge XL single would probably be the only one that would go low enough to work...just wandering if anyone out there knew of one i am missing or something custom that might work...the pic i attached is the k-edge XL
PostPosted: Fri Jan 20, 2012 8:45 pm
You could run one of the K-Edge knockoffs (Rotor is like $27, "generic" is under $20) with a front derailleur adapter (the clamp you use when your frame has no braze-on).
Still, not to be repetitive, but double guards are both a cheaper and a more reliable solution in this instance. I'm not even sure there's any weight penalty.
PostPosted: Fri Apr 06, 2012 12:04 pm
If I'm seeing the flare of the chainstays correctly, you're going to have a hard time finding anything that attaches to the seatpost that will work.
PostPosted: Mon Apr 09, 2012 6:14 pm
I recently installed a K-Edge Cross Double XL chain catcher on my 2012 Blue Norcross EX. Its mounts on the high on the seat post tube and works great on the carbon frame. The results have been fantastic. Its hard to tell from your picture because its cut off where the clamp would mount. However, I think this might work for you.
2012 Blue Norcross EX, Size: ML
PostPosted: Mon Apr 09, 2012 10:35 pm
i actually broke down and spent $60 and bought a K-edge XL single. So i think i am good to go now!!
PostPosted: Tue Apr 10, 2012 1:49 am
How'd that rig rock the E/I trails today Pat? :D
PostPosted: Tue Apr 10, 2012 11:06 am
pretty sweet other than the chain situation....which now will be corrected. Got a few strava KOM's..LOL
PostPosted: Thu Apr 12, 2012 10:42 am
That'll give me some motivation out there!
Users browsing this forum: No registered users and 2 guests
There are no new unread posts for this topic. chain drop on SRAM chain catcher
PoorCyclist
Fri May 10, 2013 4:38 am
timzcat View the latest post
There are no new unread posts for this topic. WTB chain catcher
in Wanted
113245
Fri Apr 12, 2013 7:03 am
113245 View the latest post
There are no new unread posts for this topic. Chain catcher - Is it necessary?
G6612
39
2520
Sat Aug 18, 2012 10:02 am
daj View the latest post
There are no new unread posts for this topic. Attachment(s) CDale EVO chain catcher
RobH
14
1121
Sun Jan 27, 2013 3:07 am
eric View the latest post
There are no new unread posts for this topic. Stevens Volt TT Frame?
addicted
15
1229
Thu Nov 08, 2012 5:45 am
Chirobike View the latest post
It is currently Sun May 19, 2013 9:06 am
