Post new topic Reply to topic  [ 8 posts ]
PostPosted: Fri Jan 13, 2012 5:19 pm
I have a 2011 Cronus CX.
I was wondering if anyone ever looked into having a company add disc brake tabs and reinforcement to a carbon frame?
I would assume Calfee could do this as they do tons of repairs and understand what is required to offer a warranty.
PostPosted: Fri Jan 13, 2012 8:48 pm
I'm not sure many folks would accept liability for the modification? Lots of folks modded MTB frames to accept discs when they came out but the resultant forces resulted in snapped frames and injuries to the rider. Your frame wasn't designed to be stressed in those location so any adaptation would probably require additional strengthening. Finally, your frame is designed for a 130mm OLN rear hub whereas most disc hubs are 135mm - 130s exist, but aren't common.
Just ride
PostPosted: Sat Jan 14, 2012 1:47 am
Thanks
I figured they could provide additional support where needed since they typically do that on repairs.
I thought about the 130 vs 135mm problem.
I remember when we went from 7 to 8 speeds.
Steel frames were easy to flex to accept the wider hubs.
Oh well, I will ride it in Winter and cross races.
I also have a MTB 29er that I could convert if I really wanted a disc equipped cross bike.
PostPosted: Mon Jan 16, 2012 2:56 pm
I am considering this for a Ridley X-Night but I suspect for this to work, it will require a complete redesign of the rear triangle, not just the addition of post mounts.
PostPosted: Mon Feb 13, 2012 8:38 pm
I also have to look at the amount of CX mud racing I do.
Since it is never too bad here for cross, it would be a waste of money.
PostPosted: Sun Feb 26, 2012 3:03 pm
Calfee has been successful in adding disc tabs to carbon forks. In fact, there is an option on there new Adventure carbon frame for an ENVE carbon fork with disc tabs that they added. I am not certain if they add disc tabs to other forks. I don't see why they couldn't since they have done it before.
PostPosted: Mon Feb 27, 2012 5:38 am
Look at the picture at the bottom of this page:
http://www.rodbikes.com/articles/brakes.html
Typically it is a very bad idea to jury rig disc brake tabs onto a fork or frame that wasn't designed to handle the additional stress from disc brakes. For cross maybe it's ok because of the low speeds and flat courses, but I certainly would never do that with a road bike. For what you'd pay for a disc conversion, you'd probably come close to what you could buy a new disc-compatible cross frame.
PostPosted: Mon Feb 27, 2012 6:36 am
http://www.rodbikes.com/articles/brakes.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Not so fast. Calfee adds their disc tabs to an ENVE fork and they have undergone stringent testing to make sure the fork is strong enough to handle the braking force. Per Calfee webpage, "We had our ENVE disc brake fork tested by ACT and it passed the EN 14781: 4.9.7.3 – disc brake fatigue test."
Link here - scroll to paragraph near bottom of page.:
http://www.calfeedesign.com/carbon-fiber/model-calfee-adventure/
Users browsing this forum: Exabot [Bot] and 2 guests
There are no new unread posts for this topic. Disc brake cover
in MTB
nicemonkey
9
436
Tue Nov 06, 2012 7:44 pm
StanleyJ View the latest post
There are no new unread posts for this topic. XTR race disc brake pads
in MTB
lowpsihighspeed
Thu Feb 07, 2013 3:06 am
jonnyBgood View the latest post
There are no new unread posts for this topic. Disc Brake Road Bikes
phallenthoul
31
968
Thu Mar 28, 2013 10:31 am
Pharmstrong View the latest post
There are no new unread posts for this topic. XTR M985 Rear Disc Brake
in MTB
ipenguinking
Mon May 28, 2012 8:41 pm
purezerg View the latest post
There are no new unread posts for this topic. Attachment(s) Mechanical Disc Brake Weight Comparison
in Cyclocross / Touring
skiandbikecmh
7
971
Thu Jan 03, 2013 10:14 am
elmar schrauth View the latest post
It is currently Tue May 21, 2013 9:31 am
