Post new topic Reply to topic  [ 9 posts ]
PostPosted: Sat Dec 17, 2011 2:40 pm
I've discovered cross by virtue of moving to where trails are 5 minutes from my door. But my Ridley is a little porky at 9kg.
The frame is one bought on Cyclescheme so cannot be sold, the rest of it is fair game although I think there is little room to manoeuvre.
Spec is pretty simple.
Ridley 2011 X-Bow frame & alloy steerer carbon fork
Record 11 running gear with Campag cantis & Extralite E-Bones ISIS cranks on FSA ISIS BB.
FIR SC170 rims on Record hubs with DT Comps & brass nips
Tufo 28mm Clincher Tubs
Deda Zero 100 Bars & Stem
Fizik Arione CX Carbon saddle on Time Carbon Post
The cranks, while light at 358g are limited to lead weight bottom brackets that wear out too quickly. So they will be replaced by a pair of Extralite E-Bones QRC cranks that I already have.
I've identified that the fork is a major culprit weighing in at almost 700g! I'm looking at the Kinesis Pure CX but have a dilemma. The Kinesis fork is 405mm from crown to dropout, but the existing fork is 396mm. How much will this affect the handling? At the moment it is 73.5 STA & 72 HTA.
Tyre choice is the other are I've identified for weight loss. I ride in an area where even in mid summer there can be mud so need a tyre that clears mud well.
PostPosted: Sun Dec 18, 2011 11:49 pm
Bontrager Jones cxr tires are light at (verified) 310g each.
PostPosted: Sun Dec 25, 2011 2:31 am
F&F buddy. Crossbow is the bottom of Ridley's range so you're looking at a 1600 gram frame at a bare minimum. Time to spend $$ on some carbon or a lighter aluminum frame.
Merry Christmas everyone!
PostPosted: Sun Dec 25, 2011 11:45 am
Frame can't be changed as it was bought on a government tax loan type scheme. Have to keep it for another 2 years! :(
Forks, tyres & cranks should net about 600g or so (250+200+150) I reckon. Everything else is either top end already (Record 11) or would be too fragile for general use, if changed (wheels & cockpit).
Guess I'll have to suck it up!
PostPosted: Wed Dec 28, 2011 12:21 pm
On tyres, you might look at the 28mm Ultremos, though as you say it depends a bit on your roads. I've found the 25mm Ultremos fast comfortable and one puncture so far (c.1000km commuting through central london and the odd Windsor run).
TBH I had a bit of an aversion to them as I don't like the decals but I'm impressed.
PostPosted: Wed Dec 28, 2011 1:26 pm
Although bought on Cyclescheme, the only regular tarmac this sees is the 5 minutes to the trail & crossing roads. So I'm looking at knobblies only. Commuting is pretty much exclusively on fixed with Gatorskin Hardshell 25s until spring.
PostPosted: Wed Dec 28, 2011 4:56 pm
That's an interesting commute - or at least a tax efficient one :wink:
PostPosted: Thu Dec 29, 2011 11:07 am
its not efficient as it used to be
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Fri Feb 10, 2012 8:43 pm
Good place to take photos :D
Born in lust turn to dust, born in sin come on in!
Users browsing this forum: No registered users and 3 guests
There are no new unread posts for this topic. Ridley Helium SL Diet v2
lyot
Thu Feb 28, 2013 11:30 pm
ricey155 View the latest post
There are no new unread posts for this topic. 24,7 lbs CAAD7 on a diet!
Lopro
9
1896
Sun Sep 16, 2012 5:33 am
horse View the latest post
There are no new unread posts for this topic. New here! Cervelo R3 looking for suggestions for a diet.
SteveFromNY
26
1363
Tue Mar 26, 2013 5:04 pm
SteveFromNY View the latest post
There are no new unread posts for this topic. Advice needed, my Foil needs a diet!
simurs4
Sat Jun 16, 2012 2:53 pm
sungod View the latest post
cwdzoot
10
1353
Sun Jan 13, 2013 1:25 pm
Frans View the latest post
It is currently Sun May 26, 2013 4:25 am
