Post new topic Reply to topic  [ 11 posts ]
PostPosted: Wed Nov 30, 2011 5:13 am
just got a set of the ultimates in for the end of the season and wondered if everybody is running the 'wide' arms out stance or 'narrow' arms up stance?
they come set up with the rear in narrow and the front in wide so that is how they are for the moment. any opinions on which works better?
PostPosted: Wed Nov 30, 2011 11:57 am
that's how i run them.
rear narrow so i don't catch my leg during dismount/remounts. i'd change the rear to narrow if it was terribly muddy but it'd have to be very bad to risk the leg catch...PAIN
front wide because it has better modulation that way. i'd change the front to narrow if i needed more absolute power for a course and could get away with less modulation...but i don't see that ever happening
Grover's Grumblings
Grover's Garage
PostPosted: Wed Nov 30, 2011 8:43 pm
Narrow both ends.
PostPosted: Wed Nov 30, 2011 8:55 pm
When I first got them last season, I initially ran them stock (wide/narrow) but later changed them to narrow/narrow (FYI - requires Torx not hex wrench :D). I use Easton EC90 SLs and from my perspective, brake pads - Zipp Cork in this case - seems to make more difference than the stance of the canti's but YMMV.
PostPosted: Mon Dec 05, 2011 12:31 am
narrow/narrow. With the two muddy race I've done, it was hopeless even if I had been in the wide position.
PostPosted: Mon Dec 05, 2011 4:05 pm
I run mine narrow/narrow.
According to Avid "The Shorty Ultimate is available in a pre-set wide or narrow stance which allows for greater power (narrow) or increased mud clearance (wide)." Apparently the narrow stance is 20% more powerful.
Lennard Zinn has a good review of them here:
http://velonews.competitor.com/2010/10/ ... kes_147049" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
And an interesting more general discussion about canti geometry here:
http://velonews.competitor.com/2010/10/ ... der_147730" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
PostPosted: Tue Dec 06, 2011 7:50 pm
I've got mine narrow/ narrow, but they still feel a bit soft with 7900 levers. I am going to switch out pads, but the Swiss Stop blacks are usually pretty good with alu rims. May try greens.
PostPosted: Tue Dec 06, 2011 11:10 pm
Narrow/Narrow with Shimano 6700 levers. Changed the pads to Dura Ace R55C3. Much better than the SRAM pads.
PostPosted: Sat Dec 10, 2011 1:29 pm
Narrow/Narrow for me with 5700 levers.
Stock pads on aluminum rims and they've been fantastic
PostPosted: Thu Dec 15, 2011 9:56 pm
Anyone compared the Ultimate's power to the Shorty 6's?
I'm building up a 650B-wheeled bike, and will be running canti's with Tektro R200/Cane Creek SCR-5 levers. I'm not concerned about pad/rim clearance, but power/modulation is important.
Thanks.
GRAVELBIKE.COM - ride everything
PostPosted: Sun Dec 25, 2011 7:43 pm
I recently flipped mine from stock, wide/narrow, to narrow/narrow and am completely happy with them now. I get a bit more braking power and still have good modulation with Campy Chorus levers.
Just make sure you setup the cable lengths correctly, otherwise the brakes will be soft.
Users browsing this forum: No registered users and 5 guests
There are no new unread posts for this topic. WTB: Avid Shorty Ultimate GREY
in Wanted
xjbaylor
Mon Apr 08, 2013 6:55 pm
xjbaylor View the latest post
There are no new unread posts for this topic. wide sit bone width, narrow saddle width
taina
Tue Apr 23, 2013 2:21 pm
wassertreter View the latest post
There are no new unread posts for this topic. WTD - Avid BB7 brakes + Avid Speed Dial SL levers
in Wanted
t0ph0id
Thu Feb 21, 2013 11:11 pm
t0ph0id View the latest post
There are no new unread posts for this topic. Light, crazily narrow shoes
aaric
9
857
Wed Apr 24, 2013 5:39 pm
davidalone View the latest post
There are no new unread posts for this topic. The wide rim craze.
in Everything wheels
Juanmoretime
Sun May 12, 2013 3:18 am
pushstart View the latest post
It is currently Sun May 19, 2013 3:30 pm
