Post new topic Reply to topic  [ 11 posts ]
PostPosted: Sat Nov 19, 2011 9:47 pm
Not for CXing but for my 700c disc'd commuter.
Just been looking for some new wheels and tempted by some of the lighter 29er wheels (eg. Crest on Pro2 EVO) but the rims are a tad wide for road tyres, even the 28mm I commute on. FSA used to do some 700c disc wheels and Mavic has the Speedcity.
So.... are there any mid price* 700c disc wheels out there yet......? [clincher, 6-bolt]
or is it handbuilt time?
* shall we say sub £300...ish
PostPosted: Sun Nov 20, 2011 3:05 pm
that many eh? :wink:
PostPosted: Mon Nov 21, 2011 10:14 pm
130 or 135mm rear hub?
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
PostPosted: Tue Nov 22, 2011 11:48 am
135
I've found a few:
Mavic Speedcity (already mentioned) - CRC had them on offer recently... http://www.bikeradar.com/gear/category/ ... set-13993/
Reynolds Assault CX
http://road.cc/content/image/42324-reyn ... ault-cxjpg
Stans: not sure if you'd call this a factory wheel but Stans Alpha on ZTR hubs
http://www.jensonusa.com/store/product/ ... LUK&cc=GBP
FSA RD-460 - discontinued but there may be the odd pair floating about
Williams - never heard of them and they don't look cheap
http://www.bikeradar.com/news/article/w ... ook-28356/
and then you've got a load of 29er wheels which aren't quite right, as I've mentioned.
PostPosted: Tue Nov 22, 2011 5:54 pm
Shop Wrench
Just do hand built. Use a Mavic tn719 and pick your hub. Maybe look for a sale on cross max 29ers? They have some of the narrowest rims around. The older Easton xc one or xc two 29 have narrow rims as well.
PostPosted: Wed Nov 23, 2011 5:44 pm
cheers 743
I've just been reading about the Zipp firecrest rims and they run much wider rims than conventional 700c rims - I've seen comments say they are 25mm and the rim bead! This is even wider than most XC-type 29er rims (Stans Crests are 21mm), which makes me think that maybe the 29er route is the way to go. If the Zipps are fine with 23 or 25mm road tyres then so will the Crest rim.
Will read more.
PS Bonty do some 29er wheelsets too: 3 Race Lite versions
PostPosted: Sat Dec 10, 2011 6:45 pm
just an update...
Bought a front 29er Stans Crest on Hope EVO hub in the end and rode it today with a 28mm Conti GP4Season. Works fine.
Tried to fit a Hutchinson Intensive tubeless but it was just too tight so went for the clincher Conti instead. I could have got it on but I'd be in trouble out on the road if I got a terminal puncture and needed to fit a tube, so I went for the safer option instead.
I'll probably do the rear wheel like this next - Crest+Hope+GP4Season. Should be a good commuting setup I think. Disc braking on the front - what a relief! Power, feel, oh yes...
PostPosted: Sun Dec 11, 2011 1:20 am
I have been very tempted to get the Crest for my next CX disc build. I also want to run 28c tires during summer, but the Crest has a 21mm internal width, and a 60 psi max. If you run tubes, don't you worry about pinch flats? That is the only thing keeping me from the same setup, though I would love to use the same wheels on a 29er for racing.
SkidMap.Com
2011 Cannondale Scalpel
2010 Giant TCR Advanced SL
1943 Sieber Track Bike
PostPosted: Sun Dec 11, 2011 10:34 pm
I've seen the max psi thing with Crests but I've also heard reports of people running 80+ psi without any issues so I took the limit with a pinch of salt. I'm currently running 80psi in my GP4Season (with a tube) and they've been okay so far, on the two road rides I've done. Obviously if they fall apart then I'll probably re-assess my pholosphy of salt usage....
PostPosted: Thu Dec 15, 2011 2:03 pm
60 psi limit (or whatever it is on a Crest) is tubeless only AFAIK. Run whatever pressure you like with tubes!
PostPosted: Thu Dec 15, 2011 8:30 pm
From a 'price is no object' standpoint, seems like a set of Enve 29er tubulars laced 24/24 to DT240 would make for a really nice set of CX race wheels and the carbon clinchers for all-purpose/training. Unfortuantely for most of us, price is a consideration as that combo is very pricey at $2450 retail direct from Enve.
Users browsing this forum: No registered users and 1 guest
There are no new unread posts for this topic. help on disc wheels for cross
in Cyclocross / Touring
cycleforlife
16
1763
Tue Jan 22, 2013 6:53 pm
thelocust View the latest post
There are no new unread posts for this topic. Lightest Carbon/Aluminum Cross Disc Wheels?
morrisond
Fri Aug 24, 2012 1:12 am
Zen Cyclery View the latest post
There are no new unread posts for this topic. IndiFab SSR and Factory Lightweight
btompkins0112
Mon Aug 13, 2012 3:32 am
jsinclair View the latest post
There are no new unread posts for this topic. Moots Factory Tour Photos
CoblesTati
Thu Jul 12, 2012 2:28 pm
michel2 View the latest post
There are no new unread posts for this topic. Cervelo 2013 S2 Bicycle Frame. Size 56 NEW from Factory
Biplrsaba
Fri Mar 08, 2013 10:35 pm
Biplrsaba View the latest post
It is currently Sat May 25, 2013 2:16 pm
