Post new topic Reply to topic  [ 6 posts ]
PostPosted: Thu Nov 03, 2011 1:57 pm
Hello,
I use my road bike (caad8) as a touring bike, and I feel I need lower gears. Today I'm using 50.34 compact road crankset, paired with a 12-27 road cassette (10v).
I'm considering a double mountain crankset, a 40.28 Shimano XT or Sram x5 42.28, to replace the UltegraSL I have.
I'd leave a pair of pedals on each crankset: courrent road pedals to the 50.34 and mountain pedals to the 40.28.
The question is: Will this worK? I mean, will It shift properly? I'm worried about the FD performance.
I don't want triple drivetrain because I don't want to change STi (limited budget)
This is an alternative to 10s mountain cassette, with big jumps between cogs that I don't like. A 11-34 may be, and changing RD to a shimano preshadow 9v. And longer chain of course.
thankyou!
flat transitioner shimanoist
PostPosted: Thu Nov 03, 2011 2:05 pm
40 isn't big enough for the road. do it with the cassette. The big jumps on the low gears aren't going to be a big deal because you aren't generating a ton of torque when you're in those gears. Also dont cross chain.
PostPosted: Thu Nov 03, 2011 2:44 pm
For touring 40 would def work. Currently I'm running 46-36 w/12-27 and thinking about stepping down to 42-28ish range w/a 11-32/34. I haven't looked into if the mountain cranks would work w a cross bike, as far as OKish chain line and etc.
PostPosted: Thu Nov 03, 2011 4:21 pm
the issue is the FD
an MTB FD will shift well with a MTB double c/set but your road STI does not pull enough cable per click to work the FD properly. In other words, you'll be under-shifting.
A road FD will work fine with your STI but probably won't shift very well with the c/set.
I've run a Sram red FD on a 32/44 MTB chainset (mtb triple minus the granny) in the past and it was okay. Not brilliant but okay.
PostPosted: Thu Nov 03, 2011 5:00 pm
the two things that worry me are:
chainline: It seems to me that mountain cranksets put de rings further than the road ones,
FD performance: I'm not sure if the shifting is going to be "enough" precise.
The "super cassete" option is mean to be troublefree, I suppose...but, if I leave the mountain RD installed and go back to road cassette, will it shift ok?
PostPosted: Sun Nov 06, 2011 9:44 pm
Velozirrapt0r wrote:
Hello,
thankyou!
How much lower do you need to go? By changing to an 11-28 cassette and a 33 inner you'll be almost as low as you'd be on 30x27 with none of the fuss of swapping out cranks, BB & pedal system. Nor would it be necessary to readjust the front mech.
I ride with a semi-fused ankle but manage fine with a 34x25 unladen. Of you're climbing with panniers then a triple may be a better solution.
Users browsing this forum: No registered users and 1 guest
There are no new unread posts for this topic. can i use gxp mountain bb on my road bike?
roca rule
Wed Aug 29, 2012 1:01 am
roca rule View the latest post
There are no new unread posts for this topic. Sram S2200 Carbon Double Crankset (pf/bb30) with Gamut guide
Ordinaybikes
Mon Mar 25, 2013 1:45 pm
Ordinaybikes View the latest post
There are no new unread posts for this topic. Adding double road crank to single speed
daverissin
13
622
Sat Jun 16, 2012 2:55 pm
racermech View the latest post
There are no new unread posts for this topic. Mountain bike fitting, for a roadie?
in MTB
ScottGoBlue
7
713
Tue Dec 25, 2012 4:45 pm
Geoff View the latest post
There are no new unread posts for this topic. Speedplay Frog mountain bike cleats
in Wanted
Liggero
Tue Feb 12, 2013 10:43 pm
Liggero View the latest post
It is currently Sat May 25, 2013 11:59 pm
