Post new topic Reply to topic  [ 7 posts ]
PostPosted: Mon Oct 17, 2011 8:27 pm
Hi
What are the options for a pair of disc compatible hubs ?
I could use an MTB front and then would need a suitable rear, any suggestions ?
Ta
PostPosted: Mon Oct 17, 2011 10:09 pm
I run normal MTB ubs in the rear...its only 5mm.
PostPosted: Tue Oct 18, 2011 12:46 am
What frame are you using?
PostPosted: Tue Oct 18, 2011 6:55 am
In the UK then there is Hope or Goldtec. Though you aren't likely to find anything under 28 hole.
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Tue Oct 18, 2011 8:15 am
you can pick up all the main disc hubs in the UK... (CK, DT, Tune, et al)
The real issue is whether you need 130mm OLN or can handle the 135 of the MTB hubs. You can always re-space/cone the Shimano ones.
PostPosted: Wed Oct 19, 2011 2:07 pm
Running a Crux and a Planet X frame that is MTB spaced.
No issues on the CruX
PostPosted: Wed Oct 19, 2011 2:56 pm
That was meant for the OP.
135mm is the way to go for sure. No point in manufacturers building 130mm frames when 135mm disc hubs already exist.
Users browsing this forum: corredor_x and 1 guest
There are no new unread posts for this topic. Hubs for roadbike with disc brakes
kavitator
32
1004
Fri Feb 22, 2013 7:39 pm
ms6073 View the latest post
There are no new unread posts for this topic. Anyone has tried or have further info: mowa disc hubs
in MTB
Elstorma
Sat Dec 29, 2012 10:54 am
Elstorma View the latest post
There are no new unread posts for this topic. Disc brake cover
in MTB
nicemonkey
9
437
Tue Nov 06, 2012 7:44 pm
StanleyJ View the latest post
There are no new unread posts for this topic. Attachment(s) Seatpost suitable for quill modification?
strandsatt
Mon Nov 26, 2012 7:16 am
peruffo View the latest post
There are no new unread posts for this topic. XTR M985 Rear Disc Brake
in MTB
ipenguinking
Mon May 28, 2012 8:41 pm
purezerg View the latest post
It is currently Wed May 22, 2013 9:41 am
