Post new topic Reply to topic  [ 12 posts ]
 Post subject: di2 on my cross bikes
PostPosted: Tue Sep 13, 2011 10:39 am
hi guys,
im just sorting out 2 di2 groupsets for my cross bikes that ive had resprayed and which i may say look fantastic.They are a custom scott scandium frame because im so tall and have long limbs i run them with easton cx90 forks.However they have no bottle cage mounts,how would you suggest i mount the battery? They run a 31.6 seat post and due to the application i dont want to highly mod them because water will undoubtedly get in.Any ideas?
Bruce
PostPosted: Tue Sep 13, 2011 10:59 am
put it under your seat on the back of the seatpost
away for the heavy mud and once your seat is set you do not really need access the the seatbolts unless there is slippage.
that is where i would put it and you do not have alter the frame at all
nathan
PostPosted: Tue Sep 13, 2011 11:52 am
how would i mount it like that then? good idea
Bruce
PostPosted: Tue Sep 13, 2011 1:13 pm
Problem would not be modifying the harness if you do not know how, and yet not modifying the frame.
I would suggest cable tie the battery mount bracket to the seatpost. And tug it as high up as possible.
Run the main harness from the the handlebar on the toptube. And run the RD connector wire on the right seatstay.
BUT The harness may not be long enough for the FD connectors and RD connectors if run this way unless you're using a 'Large' harness on an extra-small frameset. I've not tried it that way, but it might work. Good luck!
PostPosted: Tue Sep 13, 2011 2:54 pm
you could drill a small hole in the frame and use one of the new aftermarket internal batteries.
PostPosted: Tue Sep 13, 2011 6:47 pm
this would be nice...
http://www.bikeradar.com/gallery/article/sea-otter-2011-felt-f2x-cyclo-cross-bike-29948?img=4&pn=sea-otter-2011-felt-f2x-cyclo-cross-bike&mlc=news%2Farticle#
http://www.youtube.com/watch?v=Qb7MhWmBCKg
PostPosted: Tue Sep 13, 2011 7:40 pm
Are there multiple companies offering internal batteries off the shelf? I only know of Calfee if you don't want to butcher the harness yourself. I'm not keen on spending out the kind of money calfee want (and that's before having to ship my new frame to the states to do the work), I'm also not overly confident with a soldering iron, so if anyone does know of any other internal batteries Please let me know. Sorry to hijack your thread slightly.
Can you ever have to many bikes?
PostPosted: Tue Sep 13, 2011 8:00 pm
I think that like the felt securing the battery would be good on the seat post its just a question of how do it? Or just zip tie on the down tube?
Bruce
PostPosted: Wed Sep 14, 2011 4:06 am
just two wires for the battery. i'm sure you could pay somebody to lengthen the wire for you if you're not comfortable with it. it's not hard. since it's cross, though, i would make sure the breaks are sealed with adhesive-lined heat shrink, and another piece of shrink over the two-wire bundle.
for mounting it to the post, or even on the frame in the stock location, you can use something as simple as a pair of zefal "gizmo clamp" bottle cage mounts.
replace the hardware with aluminum or nylon for weightweenieness.
PostPosted: Wed Sep 14, 2011 8:20 am
Are you going Ultegra or Dura-ace?
PostPosted: Tue Sep 20, 2011 9:18 pm
Look here!
viewtopic.php?f=10&t=93379
This is what I am using.
TED ESSENFELD
Schoorl, Noord-Holland, Nederland
Bike Pics
English Custom Steel Internal di2
Litespeed Ghisallo
PostPosted: Wed Sep 21, 2011 12:10 am
how much are they and how do you mount?
bruce
Users browsing this forum: Exabot [Bot] and 3 guests
This topic is locked, you cannot edit posts or make further replies. Post your Cross bikes here.
TerribleCadence
Fri Aug 31, 2012 1:37 pm
wasabi1 View the latest post
There are no new unread posts for this topic. TT bikes with BB30 - bikes fit for TT'ing`?
Kermithimself
11
1034
Tue Aug 28, 2012 9:34 am
Bigf1sh View the latest post
There are no new unread posts for this topic. XX1 for cross?
in Cyclocross / Touring
limba
Tue Dec 25, 2012 11:55 am
grover View the latest post
There are no new unread posts for this topic. Geekhouse Cross
noonan1970
Mon Dec 24, 2012 12:10 pm
CBJ View the latest post
There are no new unread posts for this topic. FSM CROSS 2012
FSM
Thu May 09, 2013 7:50 am
bournepeter View the latest post
It is currently Thu Jun 20, 2013 12:31 am
