Post new topic Reply to topic  [ 13 posts ]
 Post subject: Carbon Disc Fork?
PostPosted: Fri Sep 09, 2011 6:27 pm
Hey Guys, does anyone have recommendations for a good cross fork for disc brakes? Can't find too much online...
Justin
 Post subject: Re: Carbon Disc Fork?
PostPosted: Fri Sep 09, 2011 11:20 pm
http://www.chainreactioncycles.com/Mode ... elID=65378
PostPosted: Sat Sep 10, 2011 4:04 am
there's a ritchey fork that you see on a lot of custom cross bikes.
Custom English Cycles CX Bike
BMC SLC01
PostPosted: Sat Sep 10, 2011 11:22 am
http://www.lynskeyperformance.com/store ... cross.html
Lynskey uses these two on their disc crossers and sells them aftermarket. I'm a canti guy so haven't tried either.
PostPosted: Sun Sep 11, 2011 4:50 am
Wound Ups have been available for a while, Enve has new one out(tapered), the whisky No. 7(several versions) is out and the 3T luteus was supposed to be released too.
PostPosted: Sun Sep 11, 2011 3:51 pm
All those fork have the IS mount which already disappeared from mtb forks and I guess will do on cx forks as soon as disk brakes will come into the market, since now there is nothing
PostPosted: Fri Oct 07, 2011 3:42 am
I hope they end up making a non-tapered version too.
PostPosted: Wed Oct 12, 2011 8:59 pm
+1 on the non-tapered statement.
Just when you thought a decent full carbon disc fork was out there, you need a new frame to fit one... :|
PostPosted: Thu Oct 13, 2011 5:14 pm
available now
http://www.bikerumor.com/2011/10/13/new ... pot-brand/
"Step forward the climber and all those who worship at the altar of lightness" - R. Millar
PostPosted: Thu Oct 27, 2011 8:14 pm
What is an IS mount?
PostPosted: Thu Oct 27, 2011 9:45 pm
See the Enve fork above, that is IS mount
PostPosted: Fri Oct 28, 2011 5:23 pm
No, the Enve is postmount (PM)
IS stands for International Standard and has the bolt holes 51mm apart and in the same plane as the wheel axle, like this
As most (hydraulic) brake calipers are PM fitting these days then it's simpler and lighter to have a PM fork.
PostPosted: Fri Oct 28, 2011 6:45 pm
sorry you are right, had totally brain fart there, mixing up that the enve PM is the way things are going rather than the way they have been.
Users browsing this forum: No registered users and 3 guests
There are no new unread posts for this topic. Specialized Crux Fork - Replace with the disc fork version?
in Cyclocross / Touring
EnzioL
Fri Oct 12, 2012 9:49 am
scottyroyal View the latest post
There are no new unread posts for this topic. Fork or hub flex issue with disc brakes
sanrensho
Wed Jun 20, 2012 10:17 am
the_marsbar View the latest post
There are no new unread posts for this topic. Cheap carbon fork 1 1/8 - Alu or Carbon steerer.
in Wanted
Megaclocker
Fri Feb 01, 2013 5:51 pm
Megaclocker View the latest post
There are no new unread posts for this topic. Specialized Crux Carbon Disc
robsfuel
13
2356
Mon Mar 18, 2013 7:09 pm
typ993 View the latest post
There are no new unread posts for this topic. PRO Carbon Disc Shimano Tubular - Near New
cybernck
Mon Mar 04, 2013 12:09 am
cybernck View the latest post
It is currently Sun May 19, 2013 4:38 pm
