Post new topic Reply to topic  [ 2 posts ]
PostPosted: Fri Jul 22, 2011 6:40 pm
I'm thinking about building up a touring bike using some existing pieces I have with a mix of new components and have many questions. Will 07 Record shifters operate Campag triple front derailleur? Will same operate cable disc brakes? What is biggest cog 07 Record (medium cage?) derailleur handle? I'm thinking of using an IRD 12-30 or 12-32 cassette if I can get away with it. Thanks for the advice.
PostPosted: Fri Jul 22, 2011 7:23 pm
Your Campag levers will work with Avid BB7 Road calipers. When you adjust the cables, "pre-load" the lever arm before you tighten the cable fixing bolt. This will help reduce the needed cable pull/travel, and improve feel at the lever.
DaVinci tandems sells a modified SRAM derailleur that's compatible with Campag levers and Shimano cassettes. I used one for a while and it worked great.
GRAVELBIKE.COM - ride everything
Users browsing this forum: No registered users and 1 guest
There are no new unread posts for this topic. Lightest touring bike Cyclocorss excluded?
in Cyclocross / Touring
adidavas
Wed Jan 16, 2013 5:05 am
Calnago View the latest post
There are no new unread posts for this topic. C4 bike component hubs review and experience
devinci
35
3911
Mon Nov 19, 2012 11:52 pm
notthatmark View the latest post
There are no new unread posts for this topic. Nice light 31.8mm stem for XC/touring/bike packing MTB
in MTB
hjb1000
7
287
Sun Apr 07, 2013 6:15 am
Tom-s View the latest post
This topic is locked, you cannot edit posts or make further replies. Buying upgradable, light touring capable road bike for $700
flashpacker
Thu Jun 14, 2012 6:00 pm
Frankie - B View the latest post
There are no new unread posts for this topic. Dure Ace 9000 crank on a Campagnolo super record bike
Bantamben
13
667
Mon Apr 08, 2013 4:46 pm
savechief View the latest post
It is currently Wed May 22, 2013 4:23 pm
