Post new topic Reply to topic  [ 17 posts ]
Go to page 1, 2  Next
PostPosted: Wed Sep 14, 2005 8:13 am
Does anybody ever use these? Does it make sense, are they any good?
http://www.tufo.com/index.php?lg=en&mn=4&id=8
Thanks in advance,
Timo
 Post subject:
PostPosted: Wed Sep 14, 2005 8:39 am
Resident Pro
the problem is that the tubulars can move on the rim while braking or accelerating, afterwards the valve isn't parallel to the spokes anymore.
to avoid that you can glue the tufo tubular onto the rim, but afterwards you hae a clincher rim smeared with tubular glue and the advantage of fast changing tires is also away. i heard that they're nearly undestroyable, but quite heavy.
 Post subject: tufos
PostPosted: Wed Sep 14, 2005 12:47 pm
I use them on some racing wheels. I have never experienced a shift in the tire during accellerating or braking. I find they do give a nice tight feel to riding. Very similar to tubulars.
I only find one problem with them: if you train with them and you have a major slice in the tire, you are walking home. The sealant is good for most little thing you would pick up on the road.
They are great on the rollers because you pump them up to 200psi and with some models, not have a lot of wear.
Goes to personal preference and practicality. Roads where I live are crappy so I stick to conventional clinchers for training.
Hope that perspective helps.
 Post subject:
PostPosted: Wed Sep 14, 2005 10:54 pm
Not a fan.
The tread is fabulous, and the tires feel great. My tire shifted and blew out around the valve. There is no possible way to repair this, having tried everything. I'm going to cut it open and try to use it as a clincher, but I wasn't real happy. Got less than 50 miles out of it.
The rear tire lasted all winter.
I would hate to flat on a trail. I would go with good clinchers and a tubular race wheelset, or just 2+ sets of clinchers for racing.
 Post subject:
PostPosted: Mon Sep 19, 2005 8:49 pm
I trained on a pair for a full season, no issues. I've never had any shifting either. However, the idea of getting a flat that couldn't be fixed with the sealant scared me off of them. Ironically enough, after switching back to clinchers I had a rash of punctures. :evil:
 Post subject:
PostPosted: Wed Sep 21, 2005 3:40 pm
Take it you haven't used them. I commute 20 miles a day into central London on Ho Composite Carbons with NO movement at all. On the rare occasion that I've flatted they stay put even when ridden flat, unlike a traditional clincher. Absoluteley no need for glue as if they are fitted correctly the friction of the rubber foot on the rim edges is ample.
 Post subject:
PostPosted: Wed Sep 21, 2005 4:42 pm
Thanks all for the useful comments. Ultimobici, you commute on Tufo tubulars for clinchers? Very interesting. What do you do in case of a puncture? Are they easily changed? Do you carry a spare tire with you?
btw, excuse my ignorance but what are "Ho Composite Carbons"?
 Post subject:
PostPosted: Wed Sep 21, 2005 4:51 pm
If you use sealant they self-seal. Sod's law says if you don't put sealant in you'll be more likely to puncture!
http://www.tufo.com/index.php?lg=en&mn=1&id=41
 Post subject:
PostPosted: Wed Sep 21, 2005 5:19 pm
I think he meant the HICC tires - High Composite Carbon. I also used these on the road for a season.
http://www.tufonorthamerica.com/tires/special.php?seriesid=23
 Post subject:
PostPosted: Wed Sep 21, 2005 5:55 pm
Ah, that explains! I was only looking for CX tires so I didn't check their other products.
 Post subject:
PostPosted: Sun Sep 25, 2005 12:47 am
I just got a set of the Tufo LPS Tubular Clincher tires today... They make alot of sense to me becuase when you're running at a low pressure you won't get a pinch flat... but they are wicked hard to get seated, you have to do this weird mount/shimmy (get tire on rim), inflate a little bit, shimmy (get one side in), deflate, shimmy (get other side), done (reinflate, check work) sort of operation. So far they seem to work wonderfully... we'll really find out at the race tomorow! hehe
 Post subject:
PostPosted: Sun Sep 25, 2005 9:10 am
Unless your rims are a strange size they should be easy to seat with no need to inflate and deflate etc. Anyway good luck for your race!
 Post subject:
PostPosted: Sun Sep 25, 2005 11:39 pm
Tires were fantastic, as were my endo-ing skills
 Post subject:
PostPosted: Sun Sep 25, 2005 11:58 pm
skyleth which race were you at??
 Post subject:
PostPosted: Mon Sep 26, 2005 12:00 am
Suckerbrook in Auburn, NH
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
Users browsing this forum: Exabot [Bot], Majestic-12 [Bot] and 3 guests
There are no new unread posts for this topic. Why do people hate TUFO tubulars?
in Everything wheels
skiezo
20
1065
Sat Mar 23, 2013 1:36 am
fdegrove View the latest post
There are no new unread posts for this topic. Tufo clincher tubular & rim pressures
Praha19300
Sun Dec 30, 2012 4:03 am
Praha19300 View the latest post
There are no new unread posts for this topic. Tufo tubular clincher tires
1spd
Tue Oct 30, 2012 8:13 pm
1spd View the latest post
There are no new unread posts for this topic. tire lever - carbon clincher rims?
JURE
Thu Aug 30, 2012 10:04 am
JURE View the latest post
There are no new unread posts for this topic. Wtb: Enve 6.7 clincher wheel set or rims, pref Europe
in Wanted
klingej
Tue May 07, 2013 7:45 pm
klingej View the latest post
It is currently Fri May 24, 2013 12:38 pm
