Post new topic Reply to topic  [ 8 posts ]
PostPosted: Tue Jul 05, 2011 6:36 pm
I have raced the last couple of seasons on a frame with a 56 cm top tube and a 12 cm stem and the handling has felt good but I feel like I want to go a little longer. I've been looking at a cross frame with a 55.5 cm top tube, if I put a 13 cm stem with it the tt/stem lenghth will be 0.5 cm longer. How will this effect the handling, will it still be ok, or will I be too far out over the front wheel?
PostPosted: Tue Jul 05, 2011 6:47 pm
I say you'd be fine. But what can I say, I have a 54.5 TT and 14cm stem on the roadbike...
B.T.W. the total reach also highly depends on the type of handlebars you're using, some have more reach than others. What are you using?
my plastic bikes, 29ers & stable of old steel
PostPosted: Tue Jul 05, 2011 7:03 pm
I'm using Ritchey Logic WCS II with 82 mm reach.
PostPosted: Thu Jul 07, 2011 2:10 am
Unless you really need the drop that this size frame allows you (headtube length) I would choose to go up a size. A cross bike that small with a 130 mm stem is not going to handle well IMO, even the 120 mm stem on a cross bike smaller than 58 is questionable in my mind.
I feel that for the best handling the stem to toptube ratio for a cross bike is best kept a bit less than I would normally use on a road bike.
My bikes for reference:
Road has 575 TT, 120 stem
CX has 580 TT, 100 stem (could run 110)
PostPosted: Thu Jul 07, 2011 7:25 pm
Another factor is the seat tube angle. If the smaller frame has a different STA that will also affect the length of stem you need to achieve the fit you're looking for. I know it did on mine.
PostPosted: Fri Jul 08, 2011 6:51 pm
According to my experience, you will handle the bike much better with a shorter stem. 130cm is really too long, better to opt for another frame size
PostPosted: Sun Jul 10, 2011 4:31 am
Thanks for the confirmation. I was thinking it'd be too short, but I could get a really good deal on the smaller frame so I was considering the option. But it sounds like even a longer top tube and shorter stem then what I have been racing will be better.
PostPosted: Thu Jul 21, 2011 5:17 pm
Yes, I agree that a bigger frame would be a better choice as well. I run a 140mm stem on my road bike, but much prefer a setup that lets me use a 100mm (110mm max) on my CX bikes.
Users browsing this forum: No registered users and 1 guest
There are no new unread posts for this topic. WW tube with black valve stem?
Bianchi10
13
538
Sat May 04, 2013 2:58 am
kdgrills View the latest post
There are no new unread posts for this topic. Gap inside stem to fork, steerer tube
tri
Wed Sep 26, 2012 10:05 am
ttts2 View the latest post
There are no new unread posts for this topic. Attachment(s) Using stem as cable stop to allow slammed stem
in Cyclocross / Touring
skiandbikecmh
20
2845
Mon Dec 03, 2012 9:58 am
Stolichnaya View the latest post
There are no new unread posts for this topic. TT fit - top tube
Kermithimself
14
706
Mon Aug 27, 2012 12:14 am
WMW View the latest post
There are no new unread posts for this topic. Attachment(s) Eclipse Tube
Tiffster
Wed Feb 27, 2013 8:09 pm
Tiffster View the latest post
It is currently Tue May 21, 2013 11:08 am
