Post new topic Reply to topic  [ 7 posts ]
PostPosted: Thu May 05, 2011 12:55 pm
I'm going to have a set of disc wheels built up for my road trainer/commuter.
They aren't going to be superlight race wheels (sorry) but I still want them pretty light.
Any ideas for suitable rims and hubs? and spoke count and type too.
Rider is 77kg and I've probably got up to £450 to spend but would prefer £350ish (UK based)
Rear dropouts on the frame are 132.5mm so either a road width (130mm) or MTB (135mm) hubs will be fine. Both are 9mm QR.
Quite fancy the idea of the Stans Alpha rim but they aren't cheap and non-eyeletted (if that matters) so may opt for a Ambrosio Excellight or vanilla Open Pro instead. As for hubs; Hope, DT, AC, any others? Would prefer a UK seller ideally.
Ta.
PostPosted: Thu May 05, 2011 1:17 pm
I wouldn't use AC in the UK as their seals are pretty primitive and they zap through bearings quickly (they are not hard to change but.....)
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Thu May 05, 2011 8:24 pm
http://www.wheelsmith.co.uk/ He can build up Novatec hubs with interchangable bodies (for campag/shimano) with disc mounts.
PostPosted: Fri May 06, 2011 10:30 am
Ta. I've dropped Derek at Wheelsmith an email so we'll see what he says.
PostPosted: Fri May 06, 2011 3:22 pm
Of the rims you've listed the Open Pros are pretty much the bottom, often because of the eyelets coming loose etc - so eyelets aren't really something you should get hung up about. The Alpha is good but...
If you're building a 'disc only' set and if your frame is happy with 135mm rear spacing - one option to consider is just buying a 29er wheelset. You might be able to find a really good deal on a pre-built wheelset that would fit well under your budget.
Otherwise, build something similar yourself. NoTubes/Stan's Crest rims are available fairly cheap at places like Wiggle. In 29er form the weight is similar to the Alpha but the extra width is a bonus for larger volume tyres and they're generally cheaper than the road rim. Not only that but lots of 29er rims are similar/less weight than aluminum road rims without really giving up any strength (lighter from not having brake tracks basically).
Hope hubs would probably be a good choice for you being the UK. 32 spoke 3X is pretty standard on things like Crests and should be fine with your weight. I think you're still under the weight limit for the 'stock' Crest build that Stan's sell with light Alpine spokes so I doubt you'll have too many problems with a build like that.
PostPosted: Fri May 06, 2011 4:03 pm
cheers jooo, I'll look into that
Emailed Derek and he felt hub weight was less important than rim choice, and that 32h was sensible.
He initially suggested Alpha on Novatec
Alphas are clearly a light option, and I am tempted.
This page http://www.notubes.com/ZTR-Rims-C18.aspx
shows that (all 32h)
Alphas (350g) are 17mm internally
Crest (380g) are 21mm
355 (405g) are 19mm (discontinued it seems)
- so very little in it
[Alpine are 26" only and Arch are heavier]
I'll do some more webbing.... maybe a Hope Hoop (Pro2 on Crest) will be a good value buy....
PostPosted: Tue May 10, 2011 6:07 pm
Why? Won't the disk be too stiff? For general purpose riding, I'd think you'd want something with a more comfortable ride.
Nevermind.... I was thinking disk wheel..... (whoops)
http://djconnel.blogspot.com/
Fuji SL/1
Users browsing this forum: Majestic-12 [Bot] and 1 guest
There are no new unread posts for this topic. Attachment(s) 3D Printed Disc Wheel Valve Cover with wheel Magnet
RaceWareDirect
Wed Sep 05, 2012 11:04 pm
cyclenutnz View the latest post
There are no new unread posts for this topic. Disc brake caliper mounting options
in MTB
sbrdude1
Thu May 09, 2013 12:09 pm
Liggero View the latest post
There are no new unread posts for this topic. Wilier Centro 1 SR...build options
Horacio
32
4135
Sun Dec 09, 2012 4:25 pm
Horacio View the latest post
There are no new unread posts for this topic. DIY Disc Wheel
tosterbe
9
1648
Tue Aug 14, 2012 9:38 pm
DartanianX View the latest post
There are no new unread posts for this topic. 26" disc wheel(set) for use with SS
in Wanted
Griswald4x4
Fri Mar 29, 2013 3:17 am
Griswald4x4 View the latest post
It is currently Wed Jun 19, 2013 6:35 am
