700c xtr disc wheels for MTB
coach pat
by coach pat
I want to use my MTB as a back up cross bike and to commutte to work. I know can just put 26" slicks or 1.5s on but I would rather try 700c wheels.
Since I use disc brakes (XTR) can I just build a set of disc 700c wheels? I already have an extra set of XTR disc hubs.
I put some other 700 wheels on to check for tire clearence, which was fine, but had a problem with the spokes hitting the disc brake caliper.
Any tips? Ideally, I just swap out wheels when I want w/o adjusting the calipers or brakes.
Thanks for the help,
twistyaction usa
by twistyaction usa
Go for it. The interference between your disc caliper and your non-disc wheel spokes was because you weren't using a disc hub. I don't see why you'd have a problem otherwise as long as you've considered tire clearance. Any other questions? Repost with the results.
Frankie - B
by Frankie - B
Locked because of double posting. The discussion can proceed in the mtb forum.
