Post new topic Reply to topic  [ 3 posts ]
 Post subject: Ibis Hakkalugi
PostPosted: Mon Apr 11, 2011 10:38 pm
Hi guys,
After a lot of deliberating I have decided to go out and purchase the Hakkalugi in Phlemish Green.
Was just wondering what people would change from the standard build.
Frame Ibis carbon
Fork Alpha Q CX20, carbon
Rims/Wheels Easton Circuit
Tires Michelin Jet, 700 x 30c
Crankset SRAM Force
Chainwheel 50/34
Front Derailleur SRAM Force
Rear Derailleur SRAM Force
Rear Cogs SRAM Force, 10-speed: 12-27
Shifters SRAM Force Double Tap
Handlebars Ibis
Stem Ibis
Brake Levers SRAM Force
Brakes TRP Eurox CNC cantilevers
Saddle San Marco Zolcolan, Titanox rails
Seat Post Ibis
I will opt for the SRAM Force which is a good all rounder, and I will most def. change the wheels to Mavic Ksyriums, but not too sure if anything else is worth changing. Oh and I do like Dugast tires.
I am consisdering going for disc brakes at the front, any opinions?
Thanks in advance,
Mike
 Post subject: Re: Ibis Hakkalugi
PostPosted: Tue Apr 12, 2011 12:55 am
It should come with an Edge/Enve fork not Alpha Q.
If you're going to race you want tubulars and switch the chain rings to something like 48/38, 46/36 or whatever works for your courses.
I think worthwhile disc brakes are at least two years away. I wouldn't bother with them yet.
PostPosted: Sun May 08, 2011 10:52 pm
The stock bar/stem/post should be easy weight savings and then as you've already mentioned wheels. Everything else seems to be reasonably light weight.
I agree, proper cross chainrings and tubulars are a must if you're going to be racing.
http://eatrideworksleep.tumblr.com
Users browsing this forum: No registered users and 4 guests
There are no new unread posts for this topic. 2013 Ibis Hakkalügi DISC!! wow ....
in Cyclocross / Touring
giant man
39
3618
Fri Dec 28, 2012 10:56 pm
maddog 2 View the latest post
It is currently Sat May 25, 2013 2:50 pm
