Post new topic Reply to topic  [ 14 posts ]
 Post subject: CX wheelset help
PostPosted: Fri Jan 21, 2011 1:45 am
I'm trying to figure out what to do for wheels for my CX bike. I was looking into the following:
HED Belgian C2
King Classics (32 f/r)
Sapim Race spokes
Brass nipples
I use my cross bike for some road rides, mountain bike trails and I just did a cross race for the first time this past week. If I hadn't trashed the stock wheels I'd keep them and get the C4 CX tubular wheelset, but I'd rather not have to deal with tubulars all the time :| Any input is appreciated :beerchug:
 Post subject: Re: CX wheelset help
PostPosted: Fri Jan 21, 2011 7:01 am
I like the Mavic Crossmax wheels myself. I'm 200lbs and they're darn near bulletproof
PostPosted: Fri Jan 21, 2011 7:43 am
For a cross bike? I have a set of Crossmax SLRs for my mountain bike :beerchug:
PostPosted: Sun Jan 23, 2011 8:17 am
Any other recommendations?
:up:
PostPosted: Sun Jan 23, 2011 4:31 pm
Tony, you're looking for clincher rims, yes?
Velocity a23 will get you a wide strong rim, just like the hed c2's.
I would also consider DA hubs instead of the king hubs. Cup and cone bearings are great on the cx bike because you can tear down, clean, and lube up quickly to bring them back to silky spinning!
32/32 is probably overkill. If you weigh enough to need a 32 front, then you probably need a 36 rear! 28/32 is bombproof for almost everyone!
If you decide tubular is worth the hassle, the velocity major tom rims are what I'd put on there!
Have fun with the build!
PostPosted: Sun Jan 23, 2011 5:03 pm
Yeah, I'd like a clincher rim for the moment. I was wondering about the spokes, I would rather have a setup that is overkill instead of having a setup that is too flimsy. (I'm 80-82 kg) If I went with 28/32 I could also go with an Alchemy ELF/ORC combo, which is something I was thinking about too, although weight really isn't an issue with this build. I'll look into the Shimano/Velocity setup too. Thanks for the help! I'm going to see if my friend at the lbs can fix my stock rear wheel, if so I might look into some tubulars.
PostPosted: Mon Jan 24, 2011 7:31 pm
Have you thought about hope hubs?
PostPosted: Thu Mar 10, 2011 4:33 am
I second the recommendation for Shimano hubs. Parts are readily available and they are fairly easy to teardown and built up.
PostPosted: Thu Mar 10, 2011 5:17 am
King Hubs + Stans Rims = BULLETPROOF
PostPosted: Thu Mar 10, 2011 7:35 am
I would go for DA hubs anyway.
Buy them and forget them. There would be something nicer, lighter etc. than DA hubs, but in terms of reliability and longevity they are number 1 !!
PostPosted: Thu Mar 10, 2011 2:37 pm
kinlin XR 270 and Kings is what I would get.... I have had great results from both.
2 Serotta's, 1 Spectrum, 1 Van Dessel, 1 Parlee & 1 Carl Strong, & 1 Titus.
PostPosted: Tue May 10, 2011 6:47 am
If you rather have overkill 28/32 with Competition Spokes, and Velocity A23, HED C2, C-4 V22 rims would be just fine. If you go the tubular route the Major Tom as mentioned is a great rim. As well as the Kinlin TB-25, or HED C2 tubular.
http://www.pinnaclewheelworks.com
PostPosted: Tue May 10, 2011 10:35 pm
That's pretty much what I got. Hed C2s, DT Comps, 28/32 King Classics :beerchug:
They're SOLID! 8)
PostPosted: Tue May 10, 2011 11:44 pm
Nice, that will be a great wheelset.
Users browsing this forum: No registered users and 2 guests
There are no new unread posts for this topic. AX Lightness SRT 24 Premium wheelset or other <850g wheelset
in Wanted
Vuong05
Tue Apr 23, 2013 9:15 am
Vuong05 View the latest post
There are no new unread posts for this topic. What wheelset?
tenax
Fri Feb 15, 2013 9:34 am
superb View the latest post
There are no new unread posts for this topic. Which Enve wheelset?
Tamu8104
11
1453
Thu Aug 09, 2012 12:48 pm
Tamu8104 View the latest post
There are no new unread posts for this topic. Powertap G3 Wheelset
Ghost234
Sat Jun 09, 2012 2:26 am
12x23 View the latest post
There are no new unread posts for this topic. ENVE 3.4 wheelset (Must go!)
Janman
Sun Apr 14, 2013 7:35 pm
Janman View the latest post
It is currently Sat May 18, 2013 7:28 am
