Can one run 46/36 with a SRAM Force or Red crankset? If so,
It sounds like your issue might be with varying bcd between the compact (46/36) and the previous crank? I've been running a standard red crank for a bb30 with some sram cx rings I pulled from a rival crankset. I had to file down the chain drop pin on the outer ring as it was contact the crank arm. Wickwerks make some great cx rings. A quick look at their site shows a 44 option but I don't see a 42 for a two ring setup. Generally a 42 ring would be used with a single ring set up and I know those are readily available. Check out cyclocrossworld.com they carry a couple brands of rings and might have what you are looking for. Good luck!
Cant speak to SRAM, but prior to last season when I switched to Wickwerks 46/36, I had used the Thorne Koksijde rings in 44/38 and 42/38 with FSA k-Force and Cannondale Hollowgram cranks in 130 BCD. Send me a PM if you are in the US and would like a set of used rings.nayr497 wrote:Are others running SRAM cranks with 46 or 42 outer rings? I don't know if they've redesigned the spider or what and I know I had a TT/aero ring, but tech support told even a non-aero 42 wouldn't clear. (I didn't want to monkey around with cassettes, was hoping to keep my same gearing.)
SRAM sells 46/36 for 110BCD, 46/38 for 130BCD. The compact version is sold as a complete crank but not easy to get, typically it's buy a 50/34 ad get rings. I use the 46/36 on Force cranks, shifts very well.
A 36 will not fit on a 130 BCD crank, smallest ring which does is a 38. 42 is typically for a single ring setup.
after 2 drinks I'm a loser, after 3 a star
- Similar Topics
- Replies
- Views
- Last post
Sram Force 1x Crankset and Preload Adjuster question
by cassard » Wed Mar 21, 2018 4:44 am » in Cyclocross / Gravel / Touring - 1 Replies
- 147 Views
Last post by moyboy
Wed Mar 21, 2018 12:09 pm
Easton EC90 SL crankset with Force 1
by moyboy » Thu Feb 01, 2018 2:43 pm » in Cyclocross / Gravel / Touring - 4 Replies
- 702 Views
Last post by moyboy
Mon Mar 12, 2018 3:54 pm
- 0 Replies
- 413 Views
Last post by Hardstyle
Mon Jul 10, 2017 12:04 am
- 2 Replies
- 203 Views
Last post by sub7kg
Sun Feb 18, 2018 6:08 pm
- 10 Replies
- 1431 Views
Last post by youngs_modulus
Mon Aug 14, 2017 4:07 pm
