Post new topic Reply to topic  [ 12 posts ]
PostPosted: Tue Sep 02, 2008 11:10 pm
Just got some Aquasure for the side walls of my Dugast's , how and how much of this stuff should I use & do I need protective gloves when using it?
the only way is up
 Post subject:
PostPosted: Wed Sep 03, 2008 6:50 am
Resident Pro
do this in your garden, otherwise you're high after 15 minutes...
i used a plastic glove and smeared the aqua sure with the index finger.
i applied a line similar to the toothpaste i out on the brush for maybe 20 cm, smeared it with the finger so the i had a similar looking film on it, then made the next 20 cm. it gets hard quickly, that's why i did not apply it round the whole sidewall in one piece.
i usually did all my wheels on one side, waited 24 hours, then did all the other sidewalls, sitting on a small chair and having the wheel on my upper leg. it's harder to wash it off fingers and t-shirts than tubular glue, so use old clothes.
ALWAYS close the tube while you're smearing, otherwise the aquasure inside the tube dries out and you can throw it into the carbage can...
when it's dry it can be removed with a thin, sharp knife quite easily from the rim, because you can't really prevent the aquasure getting smeared onto the rim.
if you haven't glued the tubs yet: for me it was easier to apply it when the tub was alone, not glued onto a rim.
 Post subject:
PostPosted: Thu Sep 04, 2008 9:12 am
simon, do you think it is really necessary to use?
 Post subject:
PostPosted: Thu Sep 04, 2008 3:26 pm
I have aqua sealed all my dugast, and they look much nicer for longer. plus the water wont seep into the sidewall (cotton) as quick.
if you have left over aqua seal. wrap it tightly in plastic wrap and store it in the freezer, it will forever there.
 Post subject:
PostPosted: Thu Sep 04, 2008 3:38 pm
It is critical to the lifespan of the tire to use this product. It really helps protect the sidewall from deteriorating prematurely, especially if you ride in conditions that are not absolutely perfect. I think it would help kee pthe base tape from seperating as early too. Besides, who doesn't want to show a clean pair of tires?
 Post subject:
PostPosted: Sun Sep 14, 2008 10:24 pm
Is this stuff better than Bison liquid rubber?
 Post subject:
PostPosted: Mon Sep 15, 2008 8:52 am
Yes, it is better than Bison as it seems to go on easier. An alternative for UK residents (maybe available elsewhere?) is something called Seam Grip which I got from my local camping shop - used for seam sealing and mending tents/waterproofs. A little more liquid than Aquasure which actually helps spreading.
http://crossjunkie.blogspot.com
 Post subject:
PostPosted: Tue Sep 23, 2008 12:55 pm
What is the best place/online shop to purchase Aquaseal in Europe ?
seems to be a typical north american product :?
 Post subject:
PostPosted: Tue Sep 23, 2008 5:34 pm
In the Uk I get mine from Zepnat.
the only way is up
 Post subject:
PostPosted: Tue Sep 23, 2008 8:24 pm
Thx.
Ordered the lasts :wink:
 Post subject:
PostPosted: Mon Sep 29, 2008 12:02 pm
i used a plastic glove (...)
I've done the way you've described. Thanks a lot.
I read the pain you had with aquasure going on the rim, so I applied a "special curve" tape on the rim before gluing/aquasuring and i had no problem.
It look likes that (i took the tip from julmtb forum, not my wheels on the picture) :
In fact it was just 1000x harder to put the tubular on the rim (the final 15 cms) than put the aquasure :?
If somes have real advices to put the tubular on the rim without destroying is arms, i'd glad to learn (i think it was more painful to mount that s*** than climbing the Rionda including the final gravel part :lol: )
PostPosted: Tue May 24, 2011 8:56 pm
About this stuff, is it of any use to keep tan sidewalled (road) clinchers looking fresh? I love the looks of them, but after a rainy ride.. not so much.
Users browsing this forum: No registered users and 3 guests
There are no new unread posts for this topic. Orbea Aqua
Blackmarketrider
Thu May 31, 2012 5:26 pm
Krull View the latest post
There are no new unread posts for this topic. My Orbea Orca and young bro Aqua
GASer
Thu Aug 16, 2012 1:31 am
Powerful Pete View the latest post
There are no new unread posts for this topic. Attachment(s) Schwalbe Ultremo Aqua tire 700 x 23, BNIB
mdeth1313
Sat Mar 30, 2013 5:49 pm
mdeth1313 View the latest post
There are no new unread posts for this topic. M35 cable installation tips?
bontie
Tue Apr 16, 2013 6:23 am
bontie View the latest post
There are no new unread posts for this topic. Tips for removing snapped spoke threads
in MTB
Asymptotic
Tue May 22, 2012 6:00 am
sstefanov View the latest post
It is currently Tue May 21, 2013 7:01 pm
