Post new topic Reply to topic  [ 5 posts ]
PostPosted: Tue Jan 11, 2005 9:49 pm
Since I'm not competing, so suck my ^^^ **** UCI, but do like some decent brakingpower even in our - ahem - not so sunny or fair winterweather, I'm tempted of disc brakes.
Any suggestions for a shifter/lever + disc combo that actually could work? I'm so tempted of letting me have a custom made CC frame.
Oh! - Suits you sir!
 Post subject: Avid
PostPosted: Tue Jan 11, 2005 10:14 pm
Nicolai, Avid has a version of their cable actuated disc brake that is designed to work with road levers.
Success is how far you you bounce back up after being knocked down
 Post subject: Re: Avid
PostPosted: Wed Jan 12, 2005 10:36 am
Thx, Cyco. I guess that Avid might be the only alternative. Dunno if that's good or bad :?
 Post subject:
PostPosted: Wed Jan 12, 2005 11:24 am
There are reveral oppinions...Tecktro, Hayes etc. Hayes and Avid's are good. (Cannondale uses Avid's them in their CC's)
For finer bike, Formula and Hope makes fluid disk brakes for road bikes. They convert cable pull to hydraylic pressure in stem section located system.
Samu @ www.signature.fi
PostPosted: Wed Jan 12, 2005 12:56 pm
Thanks & tattis Samu, I'll study the hydraulic conversion too.
Now, if you don't mind, I'll ask a suspension fork suggestion. Not that I'm in a need of any treelog bashing, but the often uneven ice layer over our roads is jarring and shaking my amalgam fillings from my teeth :shock:
I'm also tempted of somewhat skinnier tires (when studded tires are not needed) and thus less rolling resistance. "Skinny" CC tires would gain some control with suspension.
What I have in mind, is actually MTB fork, with a reasonably large arch, so that a 700 CC tire still fits. If that's a no can do, I'll have 26 wheels (and Nokian studded icebreakers) anyway. The headset size don't matter, since the frame will eventually be tailormade around the fork this time.
In this particular case, I don't mind too much of WWism in the functional parts, just want decent and supple fork function (no need for more than 70-90 mm fork travel) in icy or near icy weather conditions.
Does Fox 80 RLT have an arch big enough to fit, say Vredestein Campo 28 mm or similar? Melike Campo, since it has nice fat knobs on the side, that can be studded easily.
Users browsing this forum: No registered users and 2 guests
There are no new unread posts for this topic. XTR M985 brake lever reversable?
in MTB
hjb1000
7
561
Wed Aug 22, 2012 3:34 pm
yourdaguy View the latest post
There are no new unread posts for this topic. Disc brake cover
in MTB
nicemonkey
9
440
Tue Nov 06, 2012 7:44 pm
StanleyJ View the latest post
There are no new unread posts for this topic. XTR race disc brake pads
in MTB
lowpsihighspeed
Thu Feb 07, 2013 3:06 am
jonnyBgood View the latest post
There are no new unread posts for this topic. XTR M985 Rear Disc Brake
in MTB
ipenguinking
Mon May 28, 2012 8:41 pm
purezerg View the latest post
There are no new unread posts for this topic. Disc Brake Road Bikes
phallenthoul
31
973
Thu Mar 28, 2013 10:31 am
Pharmstrong View the latest post
It is currently Fri May 24, 2013 6:08 am
Brake pads for mtb disc brakes & disc-brake-pads at cheap prices
