Post new topic Reply to topic  [ 4 posts ]
 Post subject: 'Cross rear spacing
PostPosted: Tue Oct 26, 2004 11:28 pm
What is the typical rear spacing for a cross bike? I figured it would be 130mm, because most crossers use Road stuff, but the Salsa las cruses frame is 135. What gives?
 Post subject:
PostPosted: Tue Oct 26, 2004 11:50 pm
I think 130mm is the standard, but some brands (the MTB brands?) use 135mm. Surly offers a steel frame with 132,5 spacing, that fits both 130 and 135 (bending the steel 2,5mm isn't too difficult).
 Post subject:
PostPosted: Tue Oct 26, 2004 11:54 pm
That sucks. Heres my dillema. I'm building a cross bike on the cheap (long story as to why) and its gonna be a single speed. What I'm gonna do is build a flip flop rear wheel that can be transferred to my fixed gear if i ever decide to go geared for cross. The fixie is 130, the salsa is 135. is there anyway I can just put a spacer on each side rather than having to buy a new axle and space it out? Also, I'm getting Pauls fixie hubs.
 Post subject: Standard
PostPosted: Wed Oct 27, 2004 6:23 am
The standard is 130mm, but before the genuses (genuii?) at the UCI banned discs many maufactures were moving to 135mm (try finding a 130mm disc hub). This ment many left them at 135, some never got there and some may have gone back.
With the fixxie it is easy, just have a spere 5mm spacer that can slide/screw on the LHS and there should still be enough axle for the nut.
Success is how far you you bounce back up after being knocked down
Users browsing this forum: Exabot [Bot] and 1 guest
There are no new unread posts for this topic. Another cross "newbie" question: rear road spacing on 135mm
in Cyclocross / Touring
LouisN
Sat Feb 23, 2013 12:46 am
LouisN View the latest post
There are no new unread posts for this topic. SL211 SuperLight rear hub / DA 7900 rear hub
headwind816
7
533
Fri Apr 19, 2013 9:59 pm
eric View the latest post
There are no new unread posts for this topic. XX1 for cross?
limba
Tue Dec 25, 2012 11:55 am
grover View the latest post
There are no new unread posts for this topic. Geekhouse Cross
noonan1970
Mon Dec 24, 2012 12:10 pm
CBJ View the latest post
There are no new unread posts for this topic. XT Cranks for Cross
owen
Mon Dec 10, 2012 4:16 am
It is currently Wed Jun 19, 2013 8:53 am
