It is currently Wed Jan 17, 2018 6:19 am
Post new topic  Reply to topic  [ 4 posts ]
 Post subject: zipp wheels
PostPosted: Fri Oct 22, 2004 7:47 pm
Hey everyone, i just picked up a slightly used set of zipp 303s from a friend for practically nothing. I planned on using these tubbies for road races etc, but i was wondering if they could "cross over" (no pun intended) to a cross bike. They are 20 hole front and 28 hole rear. I weigh 150 lbs.
 Post subject:
PostPosted: Fri Oct 22, 2004 9:02 pm
WWotY 2007
Hmm.I think it's better if you don't .
RAR wheels
Roues Artisanales
 Post subject:
PostPosted: Fri Oct 22, 2004 9:57 pm
The 303's are too fragile.
I know a friend who uses the 404 (60mm deep Rim) for Light MTB-courses. I build a bombproof "404 wheelset" only used/brought the Rim for my racer too.
The 404 Rim works perfect - and is super stiff.
But you need some special spoke setting - not the normal X-times crossed.
But It's to much writing to tell you how - I did a work at the university about this, so I would say I know a bit about experiments like this.
Well you can experiment yourself if you like to, one tip:
If you know how to, then calculate the forces on the wheel (all forces! Radial - Lateral and Axial) and divide them on the number of spokes needed to take the action of a offroadride plus the spoketension from the other spokes.
You'll see that the wheel at its optimal spokesetting isn't like the standard crossed builts at all. Theres a lot of good but also bad stuff about different builds on the net.
Principia MSLe Pro 9543g
If you accidently had to, could your bike take a smaller downhill ?
 Post subject:
PostPosted: Fri Oct 22, 2004 11:32 pm
yeah i read on roadbikereview cx forum about several guys riding 303's that broke them at last years nats, i think it was.
jeremyb
PlusOneLap.com: Everything Cyclocross
There are no new unread posts for this topic. What to inspect for when buying used (2016 Zipp 808) wheels?
in Everything wheels
Noctiluxx
Tue Dec 05, 2017 1:40 pm
dim View the latest post
There are no new unread posts for this topic. Wanted: UK -100mm Enve, Zipp Sprint or Zipp Speed Stem
in Wanted
iamalex
Sat Jan 06, 2018 1:03 pm
iamalex View the latest post
There are no new unread posts for this topic. Space for a Wahoo mount with Zipp SL Sprint + Zipp SL 70 Aero setup?
Shrike
Fri Nov 17, 2017 10:08 am
Shrike View the latest post
There are no new unread posts for this topic. Zipp SL-88 vs. Zipp SLC2 TB
TSJ
Thu Sep 21, 2017 8:55 pm
TSJ View the latest post
There are no new unread posts for this topic. Rear Derailleur Pulley Wheels / Jockey Wheels - 17t and oversized sizes - where?
prendrefeu
27
1958
Wed Jan 03, 2018 3:28 am
morganb View the latest post
Users browsing this forum: No registered users and 2 guests
cron
