It is currently Tue Oct 17, 2017 1:00 am
Post new topic  Reply to topic  [ 6 posts ]
PostPosted: Tue Aug 31, 2004 11:54 am
I'm currently running a mtb on the road 30 miles a day, 5 days a week. With potential for my milage to increase.
My current wheelset is 26 inch
XT disc / DT rev / Mavic 517 (I used to run v-brakes)
As I run disc brakes, I'd like to get a set of 700c wheels built up.
I weight 175lbs and bearing in mind I will cover 8k miles a year (road).
I'm happy to spend the cash to get a very light weight AND durable set built. My concerns are spoke strength, moving to 700c with discs (hope mini) and hub durability.
My XT hubs took about 8,000 miles before the freehub needed replacing. I've re-greased the bearings only once. Cones appeared like new.
budget £400UK - $700USD. weight 175lbs. Any suggestions?
"Ride it like you've just stolen it!"
 Post subject:
PostPosted: Tue Aug 31, 2004 12:30 pm
Site Admin
What tyre width do you want to ride?
The DT RR 1.1 is the most solid rim for tyres up to 700x28C coming in at ~420 g and should handle disc brakes without problems.
If you want to run wider tyres I'd recommend you the DT TK 7.1 (claimed 540 g) or the Mavic A719 (claimed 565 g).
As alternative Sun makes (or made?) the XTC 0° claimed to weigh 470 g, but the pair in my cellar weighs 557 g each. :(
They look very strong though.
As for the spokes I'd choose DT Super Comps.
Best compromise between weight and durability for 700C disc brake wheels IMHO.
And go for brass nipples: while braking the forces are already high on 26" wheels and they increase once more at 28".
Hubs: if you want to shed some weight compared to Shimano hubs take a look at the new DT 340 Disc - looks promising and DT hubs have a good reputation in terms of bearing durability.
Image Image
 Post subject:
 Post subject:
PostPosted: Tue Aug 31, 2004 2:23 pm
I want to ride stadard road tyres. I am mtber so clueless as to roadie stuff. I currently ride 1inch Conti GP tyres on my 26inch wheels.
likely go for 23mm or 25mm tyres.
As I'm not placing any friction or stess on the sidewalls of the rims, would carbon rims or silly light rims be more of an option for me than others, as I'm not wearing down the sidewalls?
thanks Florian!
 Post subject:
PostPosted: Sun Mar 06, 2005 2:56 pm
check the new mavic wheelset!!
I' seen Karl Platt top 20 on the worlds race them on his hardtailbike!
they are maid for 700c wheel use im disc MTBs
I think they are called speedcity or so
 Post subject:
PostPosted: Fri Mar 11, 2005 3:30 pm
When it comes to high quality rims that are durable and leightweight you should take a look at Velocity Aerohead (www.velocityusa.com). Around 400g each.
Spokes DT if you want to save some cash, otherwise Sapim CX Ray. Brass nipples for sure.
Would agree with Florian on the DT Hubs.
 Post subject:
PostPosted: Fri Mar 11, 2005 6:01 pm
why that?
28" with road tyres are sometimes even smaller than 26" with knobby mtb tyres but mostly they're allmost the same size; thus the ratio between disk size and wheel size won't change much. furthermore, i'm just guessing, a road tyre can't apply as much braking force to the ground as wide mtb can. so i don't see why there should be more stress through braking.
 Post subject:
There are no new unread posts for this topic. Wheels Manufacturing Hubs
in Everything wheels
lactatehate
10
1042
Mon Oct 24, 2016 5:33 am
Nefarious86 View the latest post
There are no new unread posts for this topic. ax lightness 25 and wheels manufacturing hubs?
campagowlo
Sun Jul 30, 2017 1:20 pm
NiFTY View the latest post
There are no new unread posts for this topic. Are there silent or very-low-freewheel-noise thru-axle hubs or wheels?
phlip
Tue Apr 18, 2017 10:07 pm
ms6073 View the latest post
There are no new unread posts for this topic. Disc brake wheels - cheap options
Milese
26
1630
Wed Aug 30, 2017 2:18 pm
PrimO View the latest post
There are no new unread posts for this topic. Road disc wheels - making the jump, what should I get?
gerryc89
Tue Mar 28, 2017 12:43 am
jeffy View the latest post
Users browsing this forum: facelessfools and 3 guests
