It is currently Fri Jan 19, 2018 8:57 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Sat May 20, 2006 11:54 am
hi guys...this morning I was thinking about using an old mtb frame to build a CX bike. i've never had one so I've some questions: :P
1) the wheels are different from mtb's? or I've to usa specific wheels?
2) can I usa a mtb frame to do it?
3) this frame has an old mtb rigid fork...I've to use a CX fork?
 Post subject:
PostPosted: Sat May 20, 2006 4:41 pm
It can be done, but here is how you can best use an MTB frame for CX. ONe, Get some older Pauls Cantis that have VERY adjustable pad height. That way you can run 700c wheels with your bike and still have the pads match up. 700s are going to hold speed better than the 26" wheels on your MTB, so it is best to go with them. however, beyond that it is pretty simple to convert.
 Post subject:
 Post subject:
PostPosted: Sat May 20, 2006 7:02 pm
135mm rear hub, I think there will be not that much clearance for the tyre, because the 2" bigger wheel diameter and the up to 34mm tyres. The geometry of an mtb is also different, your bracket will be very very high. I shouldn't do it, get a cheap cross frame. The brakes are a problem too as mentioned above.
 Post subject:
uh tried to change my post and quoted myself
if you're a mod and you see this, delete it please
 Post subject:
PostPosted: Sun May 21, 2006 1:26 pm
ok...so could be possible use a mtb frame...good!
I'll build this bike for training only, so geometry an speed are not so important...
My question is: does specifc CX wheels exist? or are only road wheels a bit stronger?
this frame already mount cantilevers combined to 26" wheels...and I want to make this project very very cheap.
There are no new unread posts for this topic. Attachment(s) Simple, safe and tough components that save weight.
Lewn777
26
4057
Sat Jun 24, 2017 2:14 am
BikeAnon View the latest post
There are no new unread posts for this topic. The stupid CX build. Disc. FlyXII (china) carbon frame. "Dura ace" Di2. 1x11. Mud.
dmcgoy
15
2243
Sat Nov 18, 2017 1:15 am
Spooger View the latest post
There are no new unread posts for this topic. Di2 questions
pdlpsher1
Thu Jan 11, 2018 7:08 am
pdlpsher1 View the latest post
There are no new unread posts for this topic. THM M3 ordering questions
Mtek
Mon Nov 20, 2017 10:18 pm
Mtek View the latest post
There are no new unread posts for this topic. More bike fit questions
uquality
Sat May 06, 2017 5:03 pm
wheelsONfire View the latest post
Users browsing this forum: No registered users and 2 guests
