Post new topic Reply to topic  [ 7 posts ]
PostPosted: Wed May 03, 2006 4:16 pm
subject says it all...
love the brakes, but mine squeal like a pig because of no toe adjustment.
how do you guys adjust it?
tia,
g
 Post subject:
PostPosted: Wed May 03, 2006 6:02 pm
Basically what I was told was "ride your bike until they become toed in". I don't know if this is correct or not, but that is one way. Another, more expensive way may be to get the Christian Heule custom brake pads from one of our euro friends. These apparently allow for toe in on spooky brakes. Do a search, there has been quite some discussion on these pads.
 Post subject:
PostPosted: Wed May 03, 2006 6:15 pm
mount the brakes on the bike, then find your Vice Grips in the tool box, then grab the front part of the brake pad with the Grips and toe it in, might need to "toe" out the rear a little too, repeat on other side.
Works well, easy, cheap.
PlusOneLap.com: Everything Cyclocross
 Post subject:
PostPosted: Sun May 07, 2006 7:36 am
good idea unless the brake boss gives out, might be ok for the criss-cross, but not the merckx/spooky setup...
:D
g
 Post subject:
PostPosted: Sun May 07, 2006 9:45 am
What Jeremy described is how many people adjust their spooky brakes, they just bend the brake a bit untill everything is how they want it to be. But with the carbon version there isn't much to bend. You definetly don't want to bend your brake bosses so the only thing you could bend on the brake itself is the rod on the brakepad, but I wouldn't advise you to do this while the pad is in the brake! If you want to go this way you shouls take the pads out and easily adjust them in a vice or something.
A good friend of mine had these brakes on for a few years and did what you originally suggested, just ride untill they stop squeeling, but he got tired of them and swapped them for the alloy version in stead.
If you can get them the Heule adjustable brakepads Dan suggested sound like a good idea to me.
 Post subject:
PostPosted: Thu Jul 06, 2006 11:27 pm
any word on these? countact? source in the US?
g
 Post subject:
PostPosted: Sun Jul 09, 2006 12:36 am
You can always modify the pad. Scribe a mark in the rear of the pad of where you think the pad should sit, then use a dremel, grinder or craft knife to add toe to the pad itself. If you choose to use a powertool, be aware that brakepads are much softer than steel and it won't take much to grind them away!
Quicker way of wearing your pads out, yes, but cheeper than over-twisting and destroying a lovely Spooky brake ;-)
Users browsing this forum: No registered users and 4 guests
There are no new unread posts for this topic. TRP CX9 mini v brakes with V brake leves?
in MTB
cyclemanpat
Mon Jun 11, 2012 4:10 pm
TheRookie View the latest post
There are no new unread posts for this topic. Spooky Supertouch
jdp211
Thu May 09, 2013 6:58 pm
jdp211 View the latest post
There are no new unread posts for this topic. Spooky HavocStaff
BikeArmsRace
9
1200
Mon Apr 15, 2013 1:42 pm
BikeTart View the latest post
There are no new unread posts for this topic. Spooky Skeletor / Havoc-Staff
Janders
21
3681
Tue Nov 13, 2012 7:19 pm
mickey View the latest post
There are no new unread posts for this topic. Carbon Brake Pad Compatibility Issues?
true
10
521
Fri Nov 09, 2012 11:33 pm
Zen Cyclery View the latest post
It is currently Wed May 22, 2013 11:41 pm
