Numbskull here needs help with Di2 Road and XTR cassette.
simplemind
by simplemind
Ignorance is bliss...right? Well, not exactly. I have an XTR wheelset that I want to use with my 11 sp Ultegra Di2 gravel bike. I didn't realize that I couldn't use a road cassette on an XTR freewheel (I know now). So I'm stuck with this brand new XTR wheelset, and a bike with new Ultegra Di2 mech's.
Is there any hope, and/or what alternatives do I have?
wingguy
by wingguy
You could use the new 'Ultegra' HG800 11-34 cassette, as the 34t hangs to the inside like 11sp XT/XTR cassettes do.
If you want smaller than that you could use an Edco 11-28 conversion cassette or similar.
simplemind
by simplemind
That's a decent alternative, thanks! Running 11-36 SRAM road cassette now on my other wheelset.
simplemind
by simplemind
wingguy wrote:
Wed Mar 14, 2018 6:24 pm
Another question...will the shifting be effected (Di2), using this cassette?
ms6073
by ms6073
Shouldn't after you re-adjust the rear derailleur for the change in cassette spacing.
wingguy
by wingguy
simplemind wrote:
Wed Mar 14, 2018 7:22 pm
The HG800 is specifically designed to be used with Ultegra R8000 and R8050 long cage mechs.
simplemind
by simplemind
wingguy wrote:
Wed Mar 14, 2018 8:06 pm
:thumbup: Gracias!
simplemind
by simplemind
Have another question...would I have an issue just using an XT/XTR 11-40 cassette with my 6800 GS mech?
IrrelevantD
by IrrelevantD
simplemind wrote:
Thu Mar 15, 2018 3:08 am
I have a 6800-GS on my Crockett. 11-32 is a tight fit, you might get a 34 to work, but I can’t see a 40t fitting.
simplemind
by simplemind
IrrelevantD wrote:
Tue Mar 20, 2018 12:54 am
I have no problem with the SRAM 11-36, and it "appears" like the arm is long enough to accomodate a larger cassette. Just hoping someone who has done this will speak up.
Thanks!
ms6073
by ms6073
Souds like the kind of issue the Wolftooth derailleur links are designed to address.
IrrelevantD
by IrrelevantD
simplemind wrote:
Tue Mar 20, 2018 2:40 am
Thanks!
Could be your bike has a slightly longer deraileur hangar, I just know that 32 is tight on mine and I think 34 would hit the top pully regardless of any b-screw adjustment. I'd also say that unless you're running rings really close to each other in size up front, you might run into an issue with how much slack a 6800 will take up. Officially the total capacity on the 6800 is 37t, with an 11-40 that's 29t right there. Doesn't leave you a lot of options in front unless you're running 1x. Not saying it can't be done... just not to be surprised if it doesn't. Wolftooth link mentioned by @ms6073 probably your best bet as it's going to effectively lenthen your hangar, but not sure if that gives you any extra capacity when it comes to the rings.
simplemind
by simplemind
ms6073 wrote:
Tue Mar 20, 2018 3:55 am
Yes, however I thought a Road Link might mess with the shifting when I use my other wheelset, which is 11-32. That's the only reason not to use a Road Link as far as I know.
Here in an interesting video describing the use of a 42t mtb cassette w/ a Shimano 105 https://www.youtube.com/watch?v=Qbg-UgQ5Pnk
TheKaiser
by TheKaiser
Here is a review of the "Ultegra" 11-34t cassette. The comments also have quite a bit of discussion regarding going bigger than that and what mods are/are not required: https://cyclingtips.com/2018/03/shimano ... te-review/
simplemind
by simplemind
TheKaiser wrote:
Sat Mar 24, 2018 5:13 pm
Thanks, a good write up. I've got it (HG800) on the bike now, just need some time on it to give a proper eval.
