It is currently Tue Jan 23, 2018 9:23 am
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Wed Sep 13, 2017 11:40 pm
So Im in the process of building my new CX bike and started getting pieces of the new Ultegra Di2.. so far I have everything but the 8070 hydraulic shifters..
The problem I have is my frame is a 2016 model with the old post mount brakes so I need to run the Shimano 785 since the new models of Dura Ace and Ultegra are flat mount.. I decided today to contact Shimano USA and asked them when the 8070 shifters would be available and asked them if it takes to long will the 9170 Dura Ace work with the new Ultegra derailleurs, or will the 785 shifters work with the new derailleurs..
I had been previously been told by 3 other sources that the 8070 shifters work perfectly fine with the 785 brakes.. I was told today by Shimano that 8070 and 9170 uses a different brake hose BH90 vs the BH59 on the 785 so the new levers will not work with the brakes!! Luckily it seems that the new derailleurs still work with the 785 shift which would make sense...
PostPosted: Thu Sep 14, 2017 5:10 pm
You can use either BH90 or BH59 on the RS785/RS685 shifters and brakes. I was running the BH59 hose for about a year and switched it over to BH90 a few months ago.
PostPosted: Thu Sep 14, 2017 7:02 pm
Any info on when they are being released? Jensonusa says 9/19
PostPosted: Thu Sep 14, 2017 8:16 pm
You don't have to switch out the banjo bolt? They just plug in?
PostPosted: Fri Sep 15, 2017 2:55 am
Some versions of BH90 have banjos, some come with olives. And the older 785 calipers use banjos but the newer ones use olives. Just get the kit that corresponds with the caliper you're using.
PostPosted: Fri Sep 15, 2017 5:24 am
The Shimano Mechanic at Canadian cross nationals last year was running 785 levers with XTR Calipers. The brakes were a little bit more on/off switch then the usual set up but not huge. as far as compatibility 9170 will work with 8000 Ultegra derailleurs.
PostPosted: Fri Sep 15, 2017 5:51 am
You have to use the bh90 hose , the connector that goes into the shifter is a different size to the bh59.
PostPosted: Fri Sep 15, 2017 2:02 pm
If I understand this correctly, you would use a BH90 hose, olive, and insert with a BH59 bolt to attach to the RS785, yes?
Alternatively, it may be more straightforward to buy a XT-M8000 caliper. Thought it seems most of them don't come with the fin pads, so that may cost more.
https://www.amazon.com/Shimano-BH59-Bra ... B00YPIT7RK
http://www.jensonusa.com/Shimano-BH-90-Olive-and-Insert
https://www.universalcycles.com/shoppin ... p?id=45177
PostPosted: Fri Sep 15, 2017 3:15 pm
I just bought this kit and installed it between my RS685 shifters and RS785 calipers.
http://www.jensonusa.com/Shimano-BH90-S ... -M596M615/
PostPosted: Fri Sep 15, 2017 5:27 pm
for ST-R9120/R9170 & ST-R8020/R8070 shifters, you will need to use the Shimano SM-BH90-JK-SSR Disc Brake Hose Kits which should allow pairing with the BR-RS505/BR-RS785 post mount calipers, and the BR-RS805/BR-R8020BR-R9120 flat mount calipers.
PostPosted: Tue Sep 19, 2017 11:20 pm
Is that the part setup that would come standard with the 9170/8070 shifter-caliper pairing?
If so, my inclination would be to buy the pairing rather than individual shifters, then sell off the flags-mount calipers.
PostPosted: Thu Sep 21, 2017 2:29 pm
Cannot say for certain as the shifter/caliper sets were not available when I ordered ours. For the ST-R9170 shifter retail box set, of the two sets I purchased about a month apart from a Japanese seller on Ebay, the first set for my wife's road bike included the correct hydraulic hoses, but the second set for my bike came with the wrong set.
There are no new unread posts for this topic. Any Focus R.A.T. users? I need some help
nemeseri
Sun Aug 06, 2017 7:21 pm
nemeseri View the latest post
There are no new unread posts for this topic. Chorus 2015+ users
Boshk
Fri Dec 15, 2017 11:31 am
Digger90 View the latest post
There are no new unread posts for this topic. Where do Weight Weenies users live?
[ Go to page: 14 5 6 7 8 ]
vinuneuro
111
10374
Thu Jan 04, 2018 1:08 am
JS300 View the latest post
There are no new unread posts for this topic. Users of the Fabric bottle cage system, opinions please.
burglarboycie
10
1385
Tue Jul 18, 2017 2:36 pm
Mrseasons View the latest post
There are no new unread posts for this topic. Carbon fiber spokes + Alloy Rim = DISASTER(for MAVIC users)
[ Go to page: 1 2 3 4 5 6 ]
ohhyeok90
80
5615
Thu Nov 16, 2017 9:57 pm
antonioiglesius View the latest post
Users browsing this forum: No registered users and 3 guests
