It is currently Tue Jan 23, 2018 9:23 am
 Post subject: Thought on wheels
PostPosted: Thu Sep 07, 2017 4:57 pm
I'm looking at building up a new cyclocross rig and I was debating between two wheelsets (I do not want custom). Any other factory built suggestions are welcome. Zipp Course 30 Disc and the Mavic Ksyrium Allroad CL. Both are are approximately the same price.The Zipps are nice because they are 2mm wider, but the allroads are CL which would let me use the new Shimano rotors.
Does anyone use either of these wheelsets or have experience with the new Shimano rotors? I'm curious to what your opinions would be .
 Post subject: Re: Thought on wheels
PostPosted: Thu Sep 07, 2017 6:26 pm
Have a look at Roval SLX24 too, a bit lighter than the Zipp's and cheaper. Really good wheels which I used all this season.
Haven't tried the new Shimano rotors but I don't really like the look of them.
/jonas l
PostPosted: Fri Sep 08, 2017 12:47 pm
I second this, also much better internals (DT Star Ratchet) than Mavic or Zipp on the hubs.
PostPosted: Fri Sep 08, 2017 3:10 pm
you don't buy rotor for theirs looks @cerro
Shimano XTR/ DURA ACE
are the best rotor
they manage heat very good
they brake better and with a better feeling than all the sram centerline
and super light crappy rotor
Only available in Centerlock tough
so you better buy wheels or hubs with center lock standard
PostPosted: Sat Sep 09, 2017 7:16 am
RT99 definitely feels and brakes worse than Sram Centerline. And it's heavier. And do not manage heat at all, so has cooling fins for that. RT99 sits more outward from the hub, what can make a difference for a frame&wheel setup with really tight tolerances.
Looks worse too ;)
Mark Twain
PostPosted: Mon Sep 11, 2017 4:30 pm
Of course you do ;) That's why I get Centerline X with a alu spider instead of the regular Centerline for my wheels :)
/jonas l
PostPosted: Fri Sep 22, 2017 8:17 pm
Was considering the same Zipps and Mavics as the OP, as well as the Ardennes+. The Rovals look like a great buy. Are you running these tubeless and, if so, did you ditch the plugs for tape?
PostPosted: Mon Sep 25, 2017 11:08 pm
I used them tubeless with plugs. Lighter than the tape :)
/jonas l
There are no new unread posts for this topic. Rear Derailleur Pulley Wheels / Jockey Wheels - 17t and oversized sizes - where?
prendrefeu
27
2042
Wed Jan 03, 2018 3:28 am
morganb View the latest post
There are no new unread posts for this topic. Big man wheels
in Everything wheels
merser
Sun Jun 25, 2017 9:51 pm
spud View the latest post
There are no new unread posts for this topic. If I buy new wheels
Bostonbull
Wed Aug 30, 2017 7:45 pm
Bostonbull View the latest post
There are no new unread posts for this topic. FSE wheels?
[ Go to page: 15 6 7 8 9 ]
CrankAddictsRich
128
18693
Sat Dec 09, 2017 8:11 pm
CrankAddictsRich View the latest post
There are no new unread posts for this topic. Wheels for a fat lad
merser
26
1649
Tue Jun 27, 2017 1:16 pm
WinterRider View the latest post
Users browsing this forum: No registered users and 3 guests
