Post new topic Reply to topic  [ 5 posts ]
PostPosted: Thu Mar 16, 2006 10:54 pm
Some WW questions:
Extralite Extrabolt set 4 for Shimano V-Brakes (the upper four bolts seen in the pic below), can they also be used to mount Spooky brakes or are they a different size?
Extralite Extrabolt set 8 V-brake pivot set (see the pic below), are such pivots the same for cantilevers? Can I use them for my Spookys?
Thanks in advance!
Timo
 Post subject: Extralite
PostPosted: Fri Mar 17, 2006 12:45 am
Timo,
I will try to do the first thing this year (second depends of your frame and fork). I will notify you if anybody hasnt' answered it yet.
Bye!
 Post subject:
PostPosted: Fri Mar 17, 2006 2:03 am
any m6 bolt can be used to mount your spookys Timo.
As long as the posts fit your fork, they will work on your cantis, there is no difference in size or such that im aware of, could always try emailing extralite for sure though.
PlusOneLap.com: Everything Cyclocross
 Post subject:
PostPosted: Fri Mar 17, 2006 10:16 am
Hi Timo,
For the brakemounts, check your frame. If you can unscrew the mounts that are on there now you should be able to replace them with the extralite one's. I haven't used the extralites, but they are all the same so they should fit your spooky's just fine.
 Post subject:
PostPosted: Fri Mar 17, 2006 10:54 pm
Thanks for the input everybody! I'll give them a try :!:
Users browsing this forum: No registered users and 3 guests
There are no new unread posts for this topic. Which fender for cyclocross
in Cyclocross / Touring
superb
Fri Mar 08, 2013 6:54 pm
superb View the latest post
There are no new unread posts for this topic. Cyclocross wallpapers
GeEk
7
1236
Mon Oct 15, 2012 10:02 am
adidavas View the latest post
There are no new unread posts for this topic. Power and cyclocross
in Training
dwilson
Thu Jul 19, 2012 7:35 am
markrhino View the latest post
There are no new unread posts for this topic. Praxis Cyclocross 36-46 available: weight?
djconnel
Sat Apr 20, 2013 10:33 am
metal View the latest post
There are no new unread posts for this topic. Which cyclocross disc bike to buy?
Kevin3182
Wed Nov 14, 2012 3:25 am
limba View the latest post
It is currently Thu May 23, 2013 11:40 am
