Focus Mares CX + Tacx Neo?
the_marsbar
by the_marsbar
I have ordered a Tacx Neo. Afterwards I came to think that maybe the Focus RAT axle might be an issue. I guess I was tight - at least Tacx doesn't sell an axle which can be used with it.
However, Meredith Miller suggested using the Kinetic Traxle with a "regular Maxle nut", with a Wahoo Kickr: https://twitter.com/rainingktula/status ... 9485930496
Do you guys think this would also work with a Tacx Neo?
Suggestions are very welcome.
ms6073
by ms6073
I am thiinking not as that solution is for the Wahopo Kicker which uses a similar mounting as the Busido/Genius/Vortex.
the_marsbar
by the_marsbar
I would really appreciate it if you could elaborate a bit more. Is the mounting mechanism on the Neo much different from the trainers you mentioned?
Otherwise I might have to return the Neo and get a Kickr...
