It is currently Sat Dec 16, 2017 2:36 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Wed Oct 26, 2016 6:40 pm
I'm on the hunt for a new cross bike and I've been referred to this Caadx through a friend of a friend.
He want's £410 and I'm just wondering if you guys think it's worth it?
I can't determine the frames age, thinking 2012 but not certain? Forks look quite old as well?
Cheers!
PostPosted: Wed Oct 26, 2016 7:44 pm
Any info on the rest of the build ?
PostPosted: Wed Oct 26, 2016 7:47 pm
Yeah, it's a little bit of a pic and mix:
Shimano Ultegra 6700 rear derailleur
Shimano 105 5700 RH shifters
Sram Force left brake lever
FSA SLK cantilever brakes
FSA SLK chainset 38t
Shimano R500 wheels
Vittoria Cross XM pro tyres
Fizik Aliante saddle
Cannondale C2 seatpost
FSA SLK stem
Deda handlebar
Shimano M520 pedals
I thought the bit's second hand add up to £200 max, then probably £200 again for the frameset?
PostPosted: Wed Oct 26, 2016 7:48 pm
Probably worth it if condition is ok, wheels are cheap. what size frame you after and do are you bothered by disks?
Giant XTC Team 2014
Giant TCR Advanced Pro 1 2016
PostPosted: Wed Oct 26, 2016 7:51 pm
54cm frame, perhaps slightly smaller 52/53? This is a 54cm.
That's the thing, would I be better of going for a disc framset? Is it really that much better than canti?
PostPosted: Thu Oct 27, 2016 3:07 pm
At least try one before you make up your mind.
PostPosted: Thu Oct 27, 2016 6:13 pm
Sounds like it may be too big for you, best get something that fits even if it costs a bit more as there's nothing worse than trying to fit yourself into a larger than required bike.
PostPosted: Thu Oct 27, 2016 6:20 pm
Well, I ride a 54" roadie, I was just thinking perhaps a slightly smaller size would be more flickable for off road.
PostPosted: Thu Oct 27, 2016 7:48 pm
It's a decent spec, assuming it all works, and a year or two back you wouldn't have paused. Nowadays with discs so prevalent you have to ask if you can be bothered with canti brakes. You'll have to decide that for yourself.
There are no new unread posts for this topic. Wheelset advice....opinions wanted
in Everything wheels
Lrdchaos
Fri May 12, 2017 4:55 pm
Asteroid View the latest post
There are no new unread posts for this topic. Cervelo R2 - Noobie - Advice wanted!
kimkimtwotwo
7
1578
Mon Apr 03, 2017 4:49 am
nvroadie View the latest post
There are no new unread posts for this topic. Widest Gravel tire on CAADX (Disk)
Crankycolnago
Tue Jan 17, 2017 11:45 pm
wheelsONfire View the latest post
There are no new unread posts for this topic. Ryan goes offroad with a 2016 Cannondale Caadx
RyanH
26
3776
Tue Jan 24, 2017 11:16 am
mattr View the latest post
There are no new unread posts for this topic. Sticky rubber wanted
Alumen
13
844
Mon Dec 11, 2017 7:14 am
jj911c2 View the latest post
Users browsing this forum: LAN and 3 guests
