Flat mount discs - worth the wait and cost?
I'm in the process of deciding on a gravel bike, my front runners being the Parlee Chebacco and Open U.P.
Both of the current versions do not have flat mount disc brakes, and because of this I understand that Parlee frames might be going on sale soon. So the question is, should I buy now, potentially for less money, or wait for new models with flat mount compatibility? Is it much better? I'm new to this disc brake game!!
2014 Parlee Z-Zero DADi2 & ENVE (6.2kg)
2015 Colnago C60 RSWH Campag Chorus & Mavic SLR (c.7kg)
On the Chebacco the updated version is switching to flat mount. I have a deposit down on one, so I'm hopefully near the front of the line
What made you choose the new version? Just the flat mount? Is it that much better?
I took the discount and got a post mount fork and IS frame.
Reason being flat mounts are designed for 140mm but I'm 180 pounds and plan to use 160mm,which negates the flat mount advantage if I were to use an adapter.
Figured I probably won't be upgrading the brake calipers or I can use mtb's version if I really want to.
The big discount on current frames are too nice to resist,espexially when the frames ride the same.
greentimgreen wrote:What made you choose the new version? Just the flat mount? Is it that much better?
Actually I'm waiting for either Dura Ace 9170 or eTAP HRD to come out, so waiting for the flat mount update wasn't a problem
fordred wrote:Reason being flat mounts are designed for 140mm but I'm 180 pounds and plan to use 160mm
With Shimano BR-S805, the front mounting plate is reversible, allowing the use of either 140 or 160mm rotors simply by flipping the mounting plate. I am 180 lbs (~81 kg) and running 140 mm Shimano Freeza rotors front and rear on a KTM Revelator Sky road bike and braking is very good (1-finger modulation). A friend of mine who at 6'6' (198 cm), is close to 200 lbs., and he just started riding a 2017 BMC Road Machine 01 with Di2 hydraulic and it came stock with 160 front, 140 rear and he has told me he has no issues with braking whether on flat roads or fast descents. To run 160 mm rotors in the rear simply requires the addition of the Shimano SM-MA-R160 adapter plate under the caliper.
- Michael
ms6073 wrote:fordred wrote:Reason being flat mounts are designed for 140mm but I'm 180 pounds and plan to use 160mm
Ar, now i know...
I guess i got the impression when most the forks for flat mounts state that it's for 140mm. Didn't really read up Shimano specs.
- wheelsONfire
I wouldn't consider 140mm rotors for a gravel bike.
Bikes:
Open *UP* (2016.04.14)
- wheelsONfire
Maybe they are, but 160mm Rotors are offering better/ faster braking.
Bikes:
Just to chime in on the 160 vs 140 rotor question, it makes total sense that for cross or riding mostly flats or if you are light weight, that 140 mm rotors are adequate. However at 180 pounds (80 kg), a 140 mm rotor is totally inadequate when trying to stop from 50 km/h plus on a steep hill. I have tried a variety of different set ups and they all fail. Stopping distances are dramatically shorter with the 160 mm rotors. I know having to bring your bike to a near halt from top speed on a 10% to 20% slope is not a regular occurrence for most of us, but if it applies to you, I highly recommend 160 mm rotors.
I have the new shimano flat mount calipers. They look super clean on a frame with flat mounts which is nice. Other than that there is no difference.
- in the industry
so besides all the rotor size debate, what are peoples thoughts now on flat mount vs post mount? Are there any benefits to going flat mount, besides aesthetics? I am in the market for a new cross bike and have narrowed down to a few options with my biggest decision being whether to go flat or post mount.
