XTR Di2 front derailleur with road crank!?
From what I've seen, the max is a 40t.
http://www.bikebling.com/Shimano-XTR-FD ... 000e6x.htm
http://www.competitivecyclist.com/shima ... derailleur
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
According to these guys it should work depending on the way you mount the derailleur.
http://www.gravelcyclist.com/bicycle-te ... mment-1363
Was Planning to run either 44/34 or 44/36...
I think you will be able to get it to work. It's really a shame that Shimano hasn't come out with a good Di2 system with a clutch RD for CX.
But, if the spy shots are accurate, it will be out in the next release.
You can always run a single ring with an XTR RD, but I understand if that range won't work for you.
Xtr fd is designed for 10 tooth spacing on crank. You may run into rubbing issues if you go with a normal road crank. Remember that xtr wont work on a braze on road mount either.
Briscoelab wrote:It's really a shame that Shimano hasn't come out with a good Di2 system with a clutch RD for CX. But, if the spy shots are accurate, it will be out in the next release.
Interesting, which spy shots are those?
