Effetto corogna taper compared to Belgium gluing
New to cross and recently glued my first set of tubs, which was an interesting/challenging experience. Has anyone used this new type of carogna tape and if so, is it comparable to the Belgium method of using tape+glue.
http://www.bikeradar.com/au/road/gear/c ... gna-49925/
Norwood & Adelaide Uni CC
- rasmussloth
Have you ridden in mud yet, LeePaton?
Agree with Lee - it's awesome. All team wheels on it now and zero issues at all. Have run muds super low and several instances in the dry higher grip earlier in the season of rolling the tyre under with huge load and it hasn't missed a beat.
The real winner is you can sit in front of the telly and mount a set of tubs in 20mins. I was all for glue + Belgian tape but I'm converted.
Here sells it - http://www.hargrovescycles.co.uk/effett ... -tape.html
I assume you use the larger size for Major Tom rims.
- rasmussloth
LouisN wrote:I'm interested about what you do with such a tape when instaling a new tubular, once the rim has already a tape on it from previous installation ?
I struggled for many hours to eliminate the old tape on a (road) rim.
Louis
https://www.youtube.com/watch?v=YB88vBwKhYQ
- rasmussloth
jmaccyd wrote:Here sells it - http://www.hargrovescycles.co.uk/effett ... -tape.html
I have the Ambrosio Crono F20 rim. google says it's a 21mm rim, so I assume I need the larger tape.
- rasmussloth
Is everybody still happy with the tape at the end of the season?
