Vittoria Cyclocross tubular tires: Good or ...?
Why do I see lots of Vittoria XG or XM tubular tires for dirt cheap these days ? Half less than competition...
Are they not good ? Please explain.
Wich tubular is the best all round option for a "one set of every weather wheels" ?
Thanks
Louis
Thanks
Louis
Ah now I read this, awaiting a 'bargain' Vitttoria XG tub. Will see how it goes
Norwood & Adelaide Uni CC
this "leak" is up to 0.8-1bar, then it "seals" by itself. Know 1 guy who rode it for a while- was more than pleased. Never had "valve issue" - but it was just 2 pcs ...
Mark Twain
I can be wrong, and have plenty of examples for that
Mark Twain
@stormur, what do you mean it 'seals by itself,' am going to be using them exclusively in loose dry conditions
I use XG tubular tyres and am really happy with them (I also use Challenge Limus for mud, but that's all I've got as a comparison).
The valve/extender thing is pretty annoying, but does indeed seal itself and works fine in practise. The main bonus I've noticed is that my 'polycotton' Vittorias still look fine after a season, while the sidewalls of my Challenge tyres look terrible! I can see the Vittorias only being thrown away when they're worn out, but the Limus will probably need replacing when the sidewalls are dead.
it means it leaks up to 1 bar max during pumping, above it holds perfectly. I doubt you'll use so low pressure whatsoever, so can't see any issue here.
Mark Twain
Mark Twain
Pre-stretching the tyre now, @stormur I kind of see what you mean for potential low pressure leakage as the valve extender slots onto the the 'nozzle' for lack of a better word where the o-ring keeps it snug
Go for it if the tread works for you. I have a set of XM treads that I got for $30 and they seem to hold air just fine. I haven't glued/ridden them though...maybe going on wifey's bike...
http://demarere.blogspot.com/" onclick="window.open(this.href);return false;
I liked them when I was using them. Switched to schwalbe for the past 2 years and have been quite unpleased with them so I'm going back to vittoria and/or challenge. I don't care for the XM tread as much since it seems like a really dedicated mud tread and is pretty skiddish when it's dry and can't bite down into something. The XG's were really nice.
The XG is very similar to the classic grifo tread, but with better cornering knobs. The valve system is not the best, but it's livable for most people. I've always wondered why this tire isnt more popular. I had a set that I loved but sold them with a bike.
