Planning 2x11 with 11-40 XT cassette rear.
So the plan is:
105 11 speed hydraulic shifters.
XT 11 speed 11-40 cassette.
Which rear derailleur??
-Looking deep in internet I've found the Shiftmate 8 to use that with a Shimano XT 11 speed rear derailleur...
or:
-Found a hack to convert a Shimano 105 11 speed rear derailleur so it accepts a 11-40 cassette...
Should be 105 so, any other idea??
thanks and cheers!
or:
thanks and cheers!
- the_marsbar
- Contact:
Can't use MTB mechs with road shifters AFAIK...
Do you really need 11-40? I.e., do you need a 50-11 gear on a bike that has a 40 cog in the rear?
BTW, my long cage 6800 derailleur can shift an 11-36 without problems.
What 2 chainrings are you going to use? If you are going to live with the big jumps on that cassette, why not just a single 48 up front.
Or else, go electronic and use 50/46 (or similar) to split the difference between the cogs: 50-11, 46-11, 50-12, etc (like the oldtimers used to do)
You'd have to hack the sftware though.
