I'm about to do a CX build on a budget and my knowledge of road/cx is non existent. Therefore I need your help.
My plan is to use the following:
- SISL2 cranks
- 6770 Di2 shifters
- medium cage 6870 rd
- 1x11 setup
- brakes?
- frameset?
Now, things I need help with:
Wheel set - I have a spare Tune Prince 32h QR hub and am wondering if that in conjunction with some extralite 24h front hub can be a base for a solid wheelset? Rims would probably be http://www.light-bicycle.com/wider-700c-38mm-tubular-rims-for-cyclo-cross-road-bicycle.html would these suffice?
Frame set - I'd like a frame(size 54 as I'm 175cm) that has internal cable routing and that it has BB30 as I have the cranks already. Frame set shouldn't surpass $1000 (used is ok).
Brakes - TRP HYRD or something other?
Weight - as I'm not familiar with road peripherals, weights of brakes/levers etc, I'm not sure how low I can go with this setup. I'd like to keep it in low 7kg if possible.
Thanks for your time and I appreciate any help.
