It is currently Tue Jan 23, 2018 7:38 am
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 Next
PostPosted: Fri Sep 18, 2015 7:28 pm
need some informations about tyre clearance of the Cannondale SuperX
27.5" wheels , did someone try?
28" wheels, do 35, 38 mm fit ?
http://eliflap.it/
PostPosted: Sat Sep 19, 2015 8:00 pm
The stock SuperX comes with a 35mm Schwalbe Rapid Rob mounted, so that will clear, but there's not much lateral room. Anything more than that and you're going to run into issues once it starts packing up with mud.
PostPosted: Sat Sep 19, 2015 8:04 pm
40mm can be installed ?
http://eliflap.it/
PostPosted: Sat Sep 19, 2015 9:42 pm
Haven't tried. 40mm slick maybe, but lateral clearance will probably be super tight.
40mm knobbies, doubt it.
PostPosted: Sat Sep 19, 2015 9:53 pm
thanks
somebody can measure the inner space inside the chainstays ?
http://eliflap.it/
PostPosted: Tue Nov 24, 2015 5:26 pm
I borrowed a 52CM and was able to fit my Clement MSO 40mm. Will clearance change on different frame size ?
PostPosted: Fri Nov 27, 2015 5:06 pm
Cannondale states that they always fit the widest tire possible as stock from factory.
So you should never use wider tires than those fitted to the bike when bought.
You need about 6mm clearance from tire to chainstay, you don't want tires to rub the frame (it will be damaged).
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
PostPosted: Fri Dec 18, 2015 4:56 am
I own a 2015 56cm Super X that came with 33mm stock tires last year, I can assure you that their is MUCH more that 33mm clearance available. I will have no problem running 40's
PostPosted: Fri Dec 18, 2015 6:16 am
what about 2012 models (canti) same clearance?
PostPosted: Fri Dec 18, 2015 8:24 am
I have 2012 canti and have got some rub with 40mm studded tyres.
PostPosted: Fri Dec 18, 2015 3:21 pm
I tried a SuperX, canti model, with 40mm Clement's MSO and rode trails. It was slightly tighter then on my Crockett. I can believe that taller knobs would touch the frame. I would put some 3M clear tape just to make sure and probably check if there was rub after a ride.
Does anyone know if a CAADX has similar or more clearance ?
looks like it would fit the MSO's Image
PostPosted: Thu Dec 31, 2015 2:50 pm
The info is avaible at Cannondale. They state that widest tire is always fitted when the bike is sold.
How hard can this be?
Is it worth risking frame?
I think you will void warranty if you decide to ignore the facts.
Personally i bought a frame clear for 40mm, but i would not buy even 42mm to try.
I would ask first if it is approved.
Bikes:
Open *UP*
PostPosted: Fri Jan 01, 2016 5:36 pm
Chill
Who says his frame has warranty...?
PostPosted: Fri Jan 01, 2016 9:08 pm
i installed 650b PariMoto 38mm at rear , no issues
http://eliflap.it/
PostPosted: Fri Jan 01, 2016 10:19 pm
I think you are on the wrong forum :D. WW is about exploring the limits, and not following approved procedures and just buying what the manufacturers are pushing.
There are no new unread posts for this topic. Colnago C60 rear tyre clearance
wedgie
43
5201
Fri Apr 07, 2017 10:45 pm
jimaizumi View the latest post
There are no new unread posts for this topic. Caad12 tyre clearance
Devotional1993
Sat Mar 18, 2017 4:11 pm
mpulsiv View the latest post
There are no new unread posts for this topic. Canyon Ultimate Tyre Clearance
mogwaiboi
Sat Dec 09, 2017 3:21 am
mogwaiboi View the latest post
There are no new unread posts for this topic. Niner RLT Steel 650b max tyre clearance
jeroenfl
Tue Feb 28, 2017 2:42 am
jemima View the latest post
There are no new unread posts for this topic. BMC slr01 team machine tyre clearance (MJ 2014 till now)
Delorre
Sat Apr 08, 2017 7:31 pm
rossjm11 View the latest post
Users browsing this forum: Google Adsense [Bot] and 3 guests
