Aluminum Tubular Disc Rims
Any aluminum tubular disc (non-machined) rims out in the marketplace? Or even wheels for 15mm thru front and 12x142 rear? Price difference between alu and carbon would help when trying to get two sets built.
http://demarere.blogspot.com/" onclick="window.open(this.href);return false;
HED does a non-machined Belgium. It's not exactly cheap - almost the same price as Chinese carbon.
Velocity does a non-machined Major Tom and from memory sold non-machined Escapes at one stage (for track wheels). Most of the Escapes seem to be long gone though and they probably aren't the most suitable rims anyway.
I'm not sure if anyone sells the KinLin TB-20 or TB-25 with non-machined sidewalls, but that could also be worth a look.
If you're happy with a more classic look, there's nothing stopping you from using something like an Ambrosio Nemesis. They're basically non-machined and would look great on some bikes. The same could be said for a whole bunch of other rims like a Mavic Reflex or lots of hard anodized NOS offerings, provided they're not super-light.
My pick would be the BOR/FRM XMD 309. It's lighter and cheaper than the HED. You're also quite likely to find it pre-built with thru-axle hubs seeing as the rim does double duty on some 29er's.
Nemesis, job done
- StradaJon
- in the industry
- Contact:
The BOR 309 is a good choice for a race day wheel - it is light and asymmetric so holds tension better than expected. Can be hard to get hold of depending on if you are EU or North American based.
Strada Hand Built Wheels
http://www.stradawheels.co.uk
I ended up ordering complete wheels with BOR 309's. I'll report back how they hold up.
Got the wheels and did my first race on them last Saturday. The wheels were great, I sucked big time. FMB tubulars are quite loose on the rims, which makes easier gluing, but hopefully will not mean higher risk of rolling a tubular. Hubs are Novatec's, but might get a second set with Hope rear hub. Through axle 11spd compatible hubs are kind of hard to come by.
Wheels shipped to Canada with no problems at all.
